How much weight does the deluxe solar add? does 25% increase make sense?!
Discussion in 'Gen 3 Prius Main Forum' started by GasSaver1, Oct 28, 2013.
  1. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    The 2012 PIP is 3165lbs
    The 2012 base is something around 3050lbs
    My 2012 package 4 with deluxe solar is 3980lbs
    Is it possible that the solar package adds nearly 25% more weight?!?!?! and all on the roof?
    Does anyone know if the spring\shocks are different than the base to compensate for all the additional weight?
  2. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Where did you get the 3980? Is that maybe the GVW?
  4. GasSaver1
    GasSaver1 Member
    220
    yes I just realized my screw up! I took total gross weight. So gross weight - load capacity mac (825lbs) = 3155lbs curb weight.
  5. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Looks like it just adds about 60 lbs:
    #6
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    And thus this thread should die but, no, this is PriusChat. :ROFLMAO:
  7. priusincc
    priusincc Member
    332
    16
    NV
    I have wondered about this before. My vehicle has a little yellow caution sticker by the VIN number plate (driver's door), that says the carrying capacity of this vehicle is reduced by 12 lbs. due to modifications. I've looked at other models without the solar roof option, and they have slightly different weights- some higher/some lower. (My GVWR is 3980 lbs.)
    It would seem that the solar roof option would have a higher correction weight, but it doesn't. It would be interesting to find out how Toyota comes up with the correction weights, but it doesn't seem consistent.
  8. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    solar roof cars carry less because they are already packed with coolness! :cool:
