How much weight will the hatch floor support?
Discussion in 'Gen 2 Prius Main Forum' started by PacMan, Apr 21, 2008.
  1. PacMan
    PacMan New Member
    40
    Ive searched the web and this forum but I cant seem to find the answer to this question? How heavy of an object can I put in the hatch of my 05 prius? I bought 3 - 50 pound bags of sand this afternoon, and was hesitant to put them in the hatch since I didnt know if the floor would support it, or if it would bow inward. I have had some hatchbacks in the past and their floors were cheap particle board, which gave in to excessive weight in small areas.
    Also, what about hauling a beer keg? I'm hesitant to do this too, but will need to occasionaly after I sell my truck.
    Thanks!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The floor is fairly sturdy and will easily hold three 50 pound sacks. A beer keg shouldn't be a problem either. Make sure to use the tie-downs in case you stop fast, like hitting the back end of another car.
    Tom
  3. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I had 5 boxes of porcelain tile in my Prius last week. Each box weighed 55lbs, so a combined total of 275lbs. No ill effects on the floor and it didn't feel like the floor was bowing or anything while I was loading it. :)
  4. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I brought 450 lbs worth of garage shelving home a few months back, although the seats were down which carried some of the load. No indication of the floor flexing or complaining during loading or unloading.
    Rob
  5. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I would not be as concerned about the weight as the dispersion of the load. Three weeks ago I carried six boxes of 12x12 tiles plus a few extras, and I had no trouble. About 10 days ago, I carried 8 40-pound bags of salt on the floor of the hatch. I carefully dispersed the weight each time and had no problem with the hatch floor. The car did have an odd look from the curb, though.
    I have thought about making a sturdier support by cutting a 1/2" plywood support, but with the past performance, I think I'm OK.
    I would be a bit hesitant about placing any single object greater than 60 or 70 pounds in an area of less than two feet in diameter. There is no engineering behind this statement, just a concern about having to replace the floor!
  6. PacMan
    PacMan New Member
    40
    Thanks everyone, I feel a bit better about it now.
  7. Qlara
    Qlara New Member
    488
    The Prius hatch floor is not made of particle (cheap) board.
    It's strong plastic-molded floor (maybe it's ABS plastic or material used for outdoor Kid's playground), very sturdy but still light in weight.
  8. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    I can say for certain that the hatch floor (at least in my prius) can handle about 220 lbs in an approximate 2' area, dead center of the floor. I just finished installing my sirius antenna in the spoiler, thanks to the wonderful how-to located here on PC, and without even considering the "flimsy" hatch floor, proceeded to place all my weight on it. I did notice that the floor felt a little soft and distended approximately 1 - 2 inches, but it managed my weight without failing. I definitely wouldn't worry about a well-dispersed load of less than ~500 lbs, although I believe that will exceed the "recommended" load capacity of the prius.
  9. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    As far as the beer keg . . .
    That should be NO problem IF you:
    1. Purchase a 10 foot siphoning hose
    2. Attach one end of hose to top of keg
    3. Run other end of hose to front left seat occupant
    4. Drive home, being sure to make ample use of hose:lalala:
    By the time you arrive home, you won't care about the hatch area floor support, just the empty keg.
    Sorry, I couldn't help making the comment!:sorry:
  10. DMAC57
    DMAC57 New Member
    Round Lake IL
    Put two Newfies in the back today on a test drive. No problems whatsoever!
