How often do you change your windshield wipers?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SLO Cat Wrangler, Apr 27, 2009.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    There is a lot of info about changing stuff on the prius, however I'm not sure that I have seen anything about changing the windshield wiper blades. I wanted to know how often people change there blades? Is it a when they are damaged or hard? What after market blades do people recommend? We live is an area that does not get a lot of rain, however our car sits in the sun for most of the day and in the garage at night. If you use rain-X, how often do you apply this?
    Thanks
    Steve
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    When they streak
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    We haven't, yet.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I do it once a year right before I take it in for it's yearly NY state inspection... Unless they are really bad which I always get a year out of them since I use rain-x.
    As for the rain-x I apply it once a year and in between that year I use washer fluid rain-x additive they sell. you add like an ounce to a gallon of the cheap $1 washer fluid. Or they sell rain-x washer fluid as well with the rain-x in it. Also, when you clean your windows they now sell rain-x window cleaner which applies rain-x. It works well and I got a 2 at bj's wholesale club with a rebate for $4.
  5. Tideland Prius
    16,153
    When they streak. We do clean them regularly and park in the garage so they do last a bit longer.
  6. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    My Prius will be 4 years old by the time the next rainy season rolls around and they are ready to be changed. So, once every four years.
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Man I miss Sacramento... When I was stationed there it was like perfect weather, no rain, from April thru October. Maybe you got a weeks worth of rain all those months. And then during winter it got just cold enough for the few to frost over on the windshield...
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Bought my Prius used nearly 2 years ago. It still has the same wipers on it and they work perfectly. I have a new set ready for the first sign of failure.
  9. Leadfoot
    Leadfoot Penny pincher
    45
    Southern California
    2014 Prius Plug-in
    Prius blades are STD Toyota issue. I immediately changed them out on my new Toyotas for Rain-X blades, which work far better and last far longer. Buy 'em when they go on sale. Takes only minutes to install. Keep the old ones tucked in the trunk as spares.
    As other posters said, using Rain-X on your windshield and cleaning the blades (I do it every time I clean the windshield) adds to their life & improves performance.
    I wonder if Rain-X makes lawnmowers...because if they do, I'd buy one!
  10. connies
    connies connies
    wichita, ks
    I am having trouble changing wiper on the back window. I changed the front ones w/o a problem. Any suggestions? 2005 Prius
  11. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    I replaced the front blades withe best Rain-X blades, and the rear with a replacement filler from Toyota when I bought the car 6 months ago. I will change them next year because I'm a stickler on blades.
  12. richard schumacher
    7,663
    1,038
    United States
    Do you know about removing the hinge cover so that the blade will stand up away from the glass? Or have you done that but are having trouble getting the insert out of the blade?
  13. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Google for John1701a's website. I believe he has instructions on there.
