How often do you recharge the key?
Discussion in 'Gen 2 Prius Main Forum' started by dachshund, Oct 20, 2006.
  1. dachshund
    dachshund New Member
    I'm just curious how often people are recharging the smart key by plugging it into the dash? I had one dealer say that you never have to put it in the dash, and another dealer said to recharge about once a week.
    To be safe I'm on the once-a-week plan. :rolleyes:
    Thanks in advance for you opinions.
  2. Trevor
    Trevor Member
    352
    Staten Island, NY
    I wasn't aware that the key was rechargeable. I think the dealer was making things up.
  3. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    I thought the FOB used a non-rechargeable watch battery :huh:
  4. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    That doesn't recharge your key. It uses a standard battery that you need to replace when it dies
  5. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(dachshund @ Oct 20 2006, 02:55 PM) [snapback]335700[/snapback]</div>
    You don't recharge it. You replace the battery once every 2 to 3 years. It's just a regular calculator type battery that you can get at just about any drug store. (The manual has instructions for replacing the battery)
    The slot is for people who don't have the SKS, and for starting your car if the fob's battery ever dies. I typically only use it when I have a valet park my car. I put the fob in the slot so they know where to find it.
  6. Tideland Prius
    16,123
    <div class='quotetop'>QUOTE(dachshund @ Oct 20 2006, 11:55 AM) [snapback]335700[/snapback]</div>
    It doesn't recharge. The slot is there so that you can slot it in if the battery dies. That's something the other SKS-equipped Toyotas/Lexuses don't have. Apparently, there's a LO-BATT warning when the battery in the fob is running low and I think you can start by placing the fob close to the POWER (or Engine Start Stop) button.
  7. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    The owner's manual says the plug in the dash is for when the battery dies in the fob, so the car can read the key so that you may drive to the store and get a new battery for the fob. In other words, no "recharge" by putting it in the dash slot.
  8. dachshund
    Interesting... I thought most of the remote-type car keys get recharged when they're in the key slot. My BMW key was this way. I had the car for 6 years and never replaced a battery, and anyway this is what the dealer said.
  9. Pious
    Pious New Member
    57
    The ignorance some dealerships never ceases to amaze me.
  10. withersea
    withersea DNF is better than DNS
    1,162
    TN
    It doesn't recharge. Apparently many dealers are misinformed on this issue. My salesperson also told me that I needed to make sure I charged the key occasionally in the slot.
  11. naterprius
    naterprius Senior Member
    1,843
    Anybody know how this works on the HyCam? it has SKS, but no slot...
    Nate
  12. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(dachshund @ Oct 20 2006, 03:05 PM) [snapback]335717[/snapback]</div>
    My last car was 12 years old when I traded it, it had the original batteries in the key fobs, and the original 12V battery under the hood. To be fair, I assume the batteries in the Prius key fobs are sending out some signal all the time, whereas the one in my Volvo (Volvos rock!) was only being used when you pressed the button to open the door. The 12V battery surprised even me, I put jumper cables in the car for the last 5 years or so I drove it, expecting it to die at any time.
  13. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    We all need to make sure that, when we come across a dealer giving missinformation like this, we take the time to correct them - there are many more owners out there than on this site, and i would hate for them to be under mistaken impressions due to dealer missinformation.
  14. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The SKS fob listens for a low power signal from one of the oscillators in the Prius. When it hears the oscillator, it transmits a code using the same mechanism as if you pressed a button on the fob. Most of the time, the oscillators solicit a request when an event occurs, such as a door handle touched, a door opened, a door attempting to be locked, power button pressed, etc. I believe the room oscillator will be used occasionally to check that the fob is still in the car, but I don't know how often. Whenever the fob responds, the LED on the fob will blink.
  15. Manksgloob
    Manksgloob Member
    243
    <div class='quotetop'>QUOTE(naterprius @ Oct 20 2006, 12:11 PM) [snapback]335727[/snapback]</div>
    Hold the HyCam FOB near the Power button while powering on.
    The induction field is something like 3 inches around it.
  16. dachshund
    Regarding the recharging issue, this is great to know! I'd much rather keep it in my pocket or bag.
  17. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(naterprius @ Oct 20 2006, 03:11 PM) [snapback]335727[/snapback]</div>
    Sounds a little inconvenient if you are having your car valet parked.
  18. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(dachshund @ Oct 20 2006, 12:05 PM) [snapback]335717[/snapback]</div>
    Unfortunately dealers can say the darnest things at times. At least one dealer has said that moving the shift lever to "B" makes the Prius run on battery alone. :lol:
  19. eclectcmoi
    eclectcmoi Muffinologist
    6,764
    17
    Lakewood, CA
    Dealers don't know it all, do they?
  20. DavidTO
    DavidTO New Member
    102
    Longo Toyota told me the same thing. Put the fob in the slot once a week to recharge. Bunch of hooey!
