How often do you replace the FOB battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Aug 26, 2019.
  1. ski.dive
    ski.dive Active Member
    899
    233
    Hutchinson Island,FL. Mt. Snow,VT
    My FOB battery is 3 years old and still works fine:)
  2. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    I changed mine at three years and plan to keep changing them every three years. I have some other things around the house that use the same batteries so I use up the remaining battery life in those devices. If the batteries finally die at home it's no big deal. I keep replacements there.
    I definitely don't like taking old batteries to the hazmat disposal until they are totally used up.
    Raytheeagle likes this.
  3. Mendel Leisk
    38,776
    At least on 3rd gen, there's a warning on the dash that your fob battery is running low. When I see that I replace batteries in both fobs. The car's build date was August 2009, and I believe it's been twice now I've done a change.
    srellim234 likes this.
    49,572
    every 4-5 years
  5. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    I have been replacing about 3 years. They are dirt cheap.
  6. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I believe you have a gen 2 with SKS? In the Gen 2 owners manual it says the inside warning alarm will beep once when the battery is getting low. I had it happening to me and didn’t know the car was trying to tell me the fob battery was low. Happened when I turned the car off. Just beeped for what I thought was no reason. My spare fob on the other hand. That thing was deader than Disco when I went to use it. At least I know my key opens the door now.
  7. ski.dive
    899
    233
    Skibob: You said= Happened when I turned the car off. Just beeped for what I thought was no reason.
    ***So when you would press the 'power button' off=The car would beep once???
  8. Skibob
    2,912
    1,496
    Northern California
    Yes
  9. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    Never and I manually use the lock button to lock doors. I rarely use the key fob and that is why it is still working great and in excellent shape with 1/4 million miles. Door automatically opens as I approach.
    I've seen countless fobs with busted buttons and must be because they are used so often?
  10. Stevewoods
    Stevewoods Senior Member
    650
    997
    Seattle, WA
    Car bought NEW from the dealer in 2008.
    Still original batteries -- SKS
  11. Skibob
    2,912
    1,496
    Northern California
    That’s flipping crazy.
