How Often Should You Run the Engine?
Discussion in 'Prime Main Forum (2017-2022)' started by Russ Bohn, Aug 30, 2017.
  1. Russ Bohn
    Russ Bohn Junior Member
    31
    Overland Park, Kansas
    I may go a number of days before I need to run the engine.
    How detrimental is it to NOT operate the engine. Meaning will the gas go bad? Engine oil does not coat engine parts properly, etc.
    Would it be wise to run the engine for 15 minutes every week at a minimum for longevity purposes?
    51,155
    nah, prime engine was designed with all that in mind. it would probably be a good idea to use up the tank every 6 months or so, or at fuel stabilizer.
    Mark57 and priuscatprimeguy like this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    after about a year a warning is displayed telling you to use up your full tank of gas, or else!:eek: I haven't seen this message yet because my anniversary is November 30th
    John Clulow and bisco like this.
  4. MNdriver
    MNdriver Senior Member
    549
    577
    Priuscatprimeguy, you must have one of the first Primes on this website!
    priuscatprimeguy likes this.
  5. priuscatprimeguy
    2,730
    2,640
    :LOL::ROFLMAO: I wish I could take that honor, but there are a few before me.
  6. Trollbait
    12,351
    In the event that you do do nothing but EV driving, plug in hybrids have programing to run the engine periodically, and to start burning gas if it is getting old. The fuel tank is also well sealed, so fuel stabilizer is not needed. So you don't have to do anything.
    Now, if you were using very little gas, I would consider keeping the tank only partly filled. Then when the gas is getting old warning comes on, you can add some fresh gas, and keep the car from burning gas unnecessarily just to use up old stuff.
  7. bisco
    51,155
    we're still trying to figure out if prime does run the engine periodically. all evidence so far points to 'no'?
  8. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I drove to Lincoln, NE yesterday just to have lunch (Grilled Salmon/rice/veggie, salad, biscuits) and give the car gas engine a little workout. Nice drive, nice day, cool jazz music.
    priuscatprimeguy, joachimz and Mark57 like this.
  9. Trollbait
    12,351
    It has to do something at some point. Perhaps it just spins up the ICE with M/G1 to get oil moving, and the oil change interval is short enough to handle any moisture that works its way into the oil.
  10. bisco
    51,155
    you would think, but owners claim nothing in the manual, and thousands of miles of pure ev without the ice.
  11. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    That would be harmful to the engine. Either don't run it, or run it good. A minimum run would be something like a half-hour or more long run after it has warmed up. Engines need to be thoroughly warmed for best life. 15 minutes would contribute to sludging up the engine innards.
  12. Dm84
    Dm84 Member
    60
    38
    MA
    I find this hard to believe. When I had a Chevy Volt it periodically ran the engine for a few minutes if I didn't use the engine for 6 weeks. It only ran for 5 minutes tops when this happened.
  13. Trollbait
    12,351
    Which was likely long enough to get the motor oil hot enough to boil out any excess water that might have been in there.
  14. bisco
    51,155
    same with the pip, warm up cycle every 124 miles. originally, i thought someone mentioned 250 miles, but there's a whole thread here on no maintenance cycle.
  15. bwilson4web
    16,012
    Third tank, 2100 miles and only refueled for a 400 mile round trip out of town.
    I would avoid storing winter gas in the Prime tank because locally, Huntsville AL, it has butane that bubbles out.
