How out-of-touch can you get?
Discussion in 'Prime Main Forum (2017-2022)' started by Lee Jay, Feb 15, 2019.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    The last time I filled my Prime was August 31st, 2018.
    Yesterday, I was in Sam's Club and I noticed the price of gas was $1.799! Honestly, I haven't noticed a gas price, even at my normal fill-up place (Costco) since I filled up, and had no idea gas prices had dropped so much! How out-of-touch can you get?
    Still haven't filled up though. Still have a quarter tank left, and I've been out of town three times on this tank.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    First, I think the present national average price for "regular" is up around $2.10, so it would be prudent for you to fill up at $1.79. It likely won't stay there very long.
    Second, no matter what kind of car you own, it is NOT a good idea to drive around very long with only 1/4 tank of gas.......especially not if that gas in approaching 6 months old.
    I suggest that the right thing to do would be to fill it up.......NOW.
    And in the future when it gets down to half.......or every 6 months, whichever comes first.
    There is absolutely NO advantage in stubbornly running it down to 1/4 or less before filling.
  3. Lee Jay
    5,850
    4,030
    Yeah...there is - getting rid of the old gas.
  4. sam spade 2
    7,035
    2,798
    2017 Prius c
    I might agree with that if......someday you decided that it was time to run out most of the old gas and did that over a few days.
    I don't agree that it is ANY advantage if it takes you more than 5 months to do it.
  5. Lee Jay
    5,850
    4,030
    Well, 99% of my in-city driving can be done in all EV mode, so it basically takes an out-of-town trip to use gas, and we just haven't done very many this winter, for various reasons.
    HPrimeAdvanced and fuzzy1 like this.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    944
    Sparks, NV
    But this 7-8 gallons adds about 50 lbs. ;)
    HPrimeAdvanced likes this.
  7. fuzzy1
    10,335
    You still have Sam's Club? All ours closed shop months ago.
    Legacy gasser rules don't necessarily apply to all-electric cars, or those being used primarily as all-electric. Filling up just means he'll have a lot more gas to go stale and require otherwise unnecessary burnoffs.
    The Prime knows that this could become an issue, and is pre-programmed to address it automatically without driver intervention. The Owner's Manual also provides guidance. I suggest that you have no reasonable basis for overriding those established measures.
  8. sam spade 2
    7,035
    2,798
    2017 Prius c
    Just because it CAN be done in EV mode does not mean that it MUST be done that way.
  9. sam spade 2
    7,035
    2,798
    2017 Prius c
    Are you sure you aren't thinking of Sears ??
    I have not heard about any mass closing of any Wal Mart properties.
    Then, a small amount of gas riding around in a container is WAY more likely to "go bad" than a large amount.
    Volatile ingredients will evaporate into the large empty space faster.
    That empty space also tends to collect more moisture from condensation.
    Good design can minimize those affects but not eliminate them.
    Do whatever you think is right and I will too.
    Neither is totally wrong.
    Merkey and benagi like this.
  10. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    If he uses so little fuel he likely shouldn’t fill up completely, just keep it slightly above the low fuel warning and add the single gallon it takes to keep the light off once and a while.
    The Volts manual recommends you keep a quarter tank of gas if you don’t use fuel ⛽️ often
    HPrimeAdvanced, Merkey and fuzzy1 like this.
  11. Lee Jay
    5,850
    4,030
    My actual plan is to take a couple of trips this spring.
  12. fuzzy1
    10,335
    They closed too. Local Sears announced as closing first in January last year, Sam's announcement about followed a week later. Sears hung around until April with clearance sales, while Sam's emptied out almost immediately.
    You have now:
    Walmart is closing 63 Sam's Club stores — here's the complete list - Business Insider
    Walmart closing 269 stores, including Mass. Sam's Clubs
    List of Walmart, Sams Club store closings
    With some occasional gas use, a small amount is less likely to get old enough to go stale in the first place, and cheaper/easier/quicker to burn off as a preventative measure.
    With a very well sealed tank in a common passenger car, that empty volume is not large enough to be a concern. The rate of leakage to and exchange with the outside atmosphere is the issue.
    Moisture? This is well sealed, which not only keeps evaporative emissions contained inside, but moisture kept outside. And most fuel available to consumers today is heavily loaded with ethanol, which quickly captures that moisture and flushes it out through the engine. Sort of (though not exactly) like have 10% HEET fuel deicer in your tank all the time, vastly more than a normal retail bottle.
    #12 fuzzy1, Feb 15, 2019
  13. sam spade 2
    7,035
    2,798
    2017 Prius c
    It can't be completely sealed.
    There must be some path to allow air in to replace the gas removed.
  14. stevepea
    stevepea Senior Member
    535
    581
    If you think that's out of touch, I wanted to find some new 8-track tapes at Marshall's today...
    #14 stevepea, Feb 16, 2019
    HPrimeAdvanced, benagi and padroo like this.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Generally speaking?
    You can get pretty out of touch.
    I won't admit it anywhere, but my instincts when faced with looking for a specific item or information about an item is still to look for a "phone book" then I realize it's 2019, and we have smart phones and the internet and I don't even have a phone book.
    And I miss being able to stroll through Blockbuster video looking at the many choices of video taped movies. Asking desperately at the check out desk if the latest release was available.
    Those days kind of sucked...but I miss them.
    walterm, HPrimeAdvanced and Merkey like this.
  16. fuzzy1
    10,335
    The system is pressurized by some sort of air pump. If well sealed, the moisture pumped in with that intentional air is minuscule, very easily handled by the ethanol in the fuel.
    The moisture won't be a problem until there is some sort of natural air exchange or flow through noticeable leaks, well beyond the minimal air needed to pressurize a sealed tank . And the 'pure gas' E0 consumers should be finding any such problems long before the E10 consumers.
  17. bisco
    51,141
  18. Merkey
    Merkey Active Member
    302
    275
    Birmingham, Michigan
    stevepea, HPrimeAdvanced and bisco like this.
  19. sam spade 2
    7,035
    2,798
    2017 Prius c
    I'm surprised that we haven't had a post yet saying that gas will last forever without ethanol......and that it is the water mixed with the ethanol that causes most of the trouble.
    Both wrong, incidentally.
    dubit likes this.
  20. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Gas is moving back up here (Midwest).
