How 'smart' is enginer kit?
Discussion in 'Prius PHEV Plug-In Modifications' started by lesdit, Apr 19, 2011.
  1. lesdit
    lesdit New Member
    32
    United States
    I'm shopping for my 'new to me' 06 Prius. I have educated myself on the various Phev systems, but am still a little unclear on a couple of things :
    On the Enginer kit : This is basically an onboard 15 amp battery charger, when it's all said and done. So it does no modifications to the SOC signaling ( CAN spoof or otherwise ) ? The only way the car used extra energy is because it sees the Prius battery being more charged for a longer duration?
    If I get two 4kwh Enginer kits and parallel them, thereby getting 30 amps max charge to the Prius battery, does that degrade the Prius battery due to the high charge current ? I fear that the 7.5 AH NiMH cells don't like repeated long duration 20 to 30 amp charging. If they were a123 cells, different story.
    OK, so I pull into my garage after a run, and then charge the Enginer batteries. What method is employed to also charge my Prius battery to 80% SOC in preperation for the drive the next day ? After all, I don't get much benefit if the Prius battery is down on SOC when I hop in the car to go.
    Does the Enginer 48->240 boost converter have any provisions for external control, other than on-off ? It seems it would benefit greatly to some intelligence to allow maxing out it's output during times that the car wants more power, and throttling it back at lights/stops if the SOC is high already. Is it relying solely on Prius battery float voltage as a current limiter ?
    BMS+ boards : Would this board be any help in improving EV usage when combined with an Enginer type kit, as it seems to have some limited CAN bus spoofing ?
    Thanks for any answers to these !
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I can't answer all of your questions, since I'm just learning more about the Enginer system myself. However, here are a few things I know about the Prius:
    The Prius battery can charge or discharge at about 20-21 kW sustained (100 amps at nominal 201.6 voltage). During maximum regenerative braking, you typically reach this level.
    The useful range of the Prius battery (40-80% SOC) is 600 whr, so with 5 kW converter, you could recharge the entire battery pack in about 7-12 minutes, depending on efficiency. So you could recharge the battery pack down 1-2 bars to 80% peak SOC, in just a few minutes of idling.
    I suppose if you wanted to "pre-charge" your HV battery, you could go into ready mode, turn on the enginer pack while idle, which would charge the HV battery pack at the rate of about 5 kW, minus losses. Then turn off the vehicle and the enginer pack. Then top off your enginer pack once again.
    From Enginer's website:
    5kW is about 20 amps at 240V, not 15 amps.
  3. lesdit
    lesdit New Member
    32
    United States
    For those with the newer 5kw kit, are they seeing 20 amps to the battery, and does it hold that charge rate all the way until the Prius battery is full ? ( I guess it might depend on the method it uses to charge the Prius battery : Constant current or other )
    I'm guessing that it does *not* give you high charge rate all the way to the 80% SOC .
    How does the enginer know when the battery is full ? Just peak voltage good enough ?
    As far as the 100 amp regen current, that would be spikes and not sustained. So a dribble of 30 amps or so may be safe, maybe.
  4. Octane
    Octane Proud Member of 100 MPG Club
    384
    56
    The Swamp, Southern FL
    The current output of the Enginer system is adjustable. People with 2G have found that setting the output above 15 amps causes the car to code under certain conditions which requires a SGII or something to reset the car and get it going again. An 8kW system essentially is used to double capacity rather than double the current output.
    When you stop for the night, I recommend using whatever power is in the pack to bring your HV SOC above 70%. Under different conditions, having an SOC above 70 will cause the ICE to fire and burn off the extra charge. There are relatively few days where I can push 80% on the HV without the ICE starting and taking down the charge.
    The Enginer output can be shut off by dropping the ready signal. Also, it is configured to trim current down as the bus voltage approaches 240. This is not the ideal control scenario. It should control based on SOC of the HV but it doesn't. I'm ready to buy an Arduino controller to bring this functionality to my system.
  5. lesdit
    lesdit New Member
    32
    United States
    Octane: So you have one converter on your 8kw system ?
    Perhaps a microcontroller would help in modulating the output current for load in the hopes that it would avoid erroring out. I'm guessing the converter settings are via trim pot rather than data.... but still possible to mess with if you know some of the surrounding circuitry.
    Is the error because the 'slop factor' of the SOC vs voltage is exceeded?
    Sorry for asking so many questions. I'm an engineer. :rolleyes:
  6. Octane
    384
    56
    Les, engineers aren't all that bad. They can usually fix a leaky faucet or solder a loose wire in a heartbeat.
    I have a 4 kW unit. I've not done an installation on an 8 kW unit so I'm not exactly sure if they are delivered with one or two dc converters. That's a good question. My guess is one converter is delivered and that the cells are wired 4 kW x 2 to maintain the 50 volt output of the overall battery.
    Regarding modulating the current. The current is supposed to be DC. But, by the time that switching power supply gets done with it, I'm not quite sure what the composition of the signal is any more. I really don't think it could be modulated one bit more. :)
    Yes, the output voltage, output current and threshold voltage (used to trim current when threshold is approached) are all set by pots.
    I'm not exactly sure what you are calling the slop factor, but if it's the variation in the SOC that the HV can accept, then that's probably entirely due to HV battery temperature. As you are probably aware, the Yoda HV is well sensored and I'm sure that the Toyota BMS uses the temperature value to adjust a number of operating parameters of the HV including maximum acceptable charge before ICE burn off.
  7. lesdit
    lesdit New Member
    32
    United States
    By modulating the current, I meant low speed modulation, so for when the car wants to draw 100 amps the DC converter would try to make all the current it can. Then when the car is at a light, it makes less, as to not throw a code maybe.
    Too bad it has pots, that makes it harder to control. I saw a picture of the insides of the converter and was disappointed that it uses regular transformer cores for the inductors. Toroids would have been more efficient. The whole converter reminded me of a high power car audio amp, I'm pretty sure the case is from that parts bin.
  8. Octane
    384
    56
    I figured something like that. I was just making light of the fact that the output is so dirty, it makes a spark gap transmitter look like a precision oscillator.
    Clearly the most elegant implementation would be to read the calculated HV SOC off the CAN-BUS, bias it against the charge limits and then feed a proportional control signal back to the DC Converter. After consultation with Enginer, they did not want to provide any specifics on the converter so simply recommended running the converter at full 14 amps output and killing the ready signal when SOC hit a threshold value and turning it back on when SOC dropped below that value.
    As a side, on my 2G, I've noticed that the code occurs when running a fairly high SOC (>68%) and I'm coasting down off highway speed to take an exit and the Enginer kit is outputting >15 or so amps. I don't know if it's the current, the voltage (that may or many not be stable under different loads).
