How soon to change both water pumps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Aug 20, 2019.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    I don't see any recommendation of how soon should change Engine Water pump? And there are inverter water pump too right. As it goes bad, overheat while driving.
    3 Gen Engine Water Pump after market about $300. I'm look to change since I'm going to change both engine and inverter coolant anyway. Any input are welcome.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    200k miles
    Sr5dude and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Did the engine water pump on our old 2010 at 175 k miles and the inverter water pump at 199 k miles;).
    Worked for us(y).
    Sr5dude likes this.
  4. R_W
    R_W Member
    82
    25
    The water pump on my 2010 died at 185k. Haven't done anything with my inverter pump yet at 197k.
  5. schmuber
    schmuber Member
    115
    84
    Georgia
    250K chiming in. Both pumps work well so far, no need to replace.
  6. CR94
    CR94 Senior Member
    2,696
    1,174
    Northwestern S.C.
    Related question:. Do these pumps typically provide warning symptoms before failure, for example, unusual noise or slightly higher coolant temperature?
  7. Tekken
    Tekken Member
    257
    77
    I guess too early to conclude it yet.. It's about averagely change Engine water pump on 150K+ miles. ??
    Raytheeagle likes this.
  8. Tekken
    Tekken Member
    257
    77
    Have you done any service or replace the HV battery on your 250K miles prius
  9. schmuber
    schmuber Member
    115
    84
    Georgia
    Other than general maintenance (fluid, brakes, EGR cleaning etc)? Yes, I had to replace the head gasket a few thousand miles back. Soon will have to replace one of the wheel bearings (it's been "dying" for the last 100K or so), shocks & struts. That's it, HV battery never gave me a problem so far.
