How sophisticated is the Prius' battery monitor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rich12, Jan 19, 2014.
  1. Rich12
    Rich12 Member
    176
    29
    Curious if the Prius MFD uses a simple voltage-drop monitor for the HV battery SOC or there are more sophisticated methods to test?
  2. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    The monitor uses coulomb counting and voltage monitoring to calculate the state of charge. (sophisticated)
    John (Britprius)
  3. Britprius
    5,194
    1,917
    Duplicate post
    John (Britprius)
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    You should do what I just did a couple of days ago. I bought a cheap android phone ($22) that I don't use as a phone. I downloaded the torque app for android and bought an ELM327 OBDII bluetooth adapter from Ebay for $10.
    I now have access to engine rpm, engine coolant temp, and many other parameters which Toyota did not believe that an average driver would want to see. I also have access to HV battery block voltages, MG1 and MG2 rpm and torque, etc.
    So for less than $40, you can have a monitoring system that is superior to Scangauge II and Ultragauge.
    GrumpyCabbie likes this.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    And throws battery temperature as well into the mix, if I am not mistaken.
