How to absolutly prevent the engine from starting? (battery only emergency)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by different.eli, Feb 11, 2025.
  1. different.eli
    different.eli Junior Member
    Vermont
    i don't care if it throws codes or lights up the dashboard like a Xmas tree, don't care if the drive is slightly disfunctional. i have coolent in my oil and would like to use the batteries Only to drive it to the mechanic.
    can i pull a fuse? disconnect the starter?
    i have a bluetooth OBDll code scanner if i can do it that way.
    Long story:
    Last night when it was -5degrees out the engine started when i turned on the car and sounded super clunky and was jerky. thought i was just cold, after 20seconds turned it off and restarted the car and drive home on just batteries.
    Today looked under the oil fill cap and saw the dreaded frozen white foam. had to move the car out of the way and it did briefly start and sounded normal (32degrees out). Which makes me think i had this problem for a while and not noticed, altho i've started it when it's much much colder out and it's sounded fine.
    If i have to take it to a mechanic that is out of battery range (i live rural) do you think i can just change the oil and that would give me chance to not completely destroy the engine? also recommendations for changing oil with an oil extractor pump if i can't warm up the engine...
  2. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    You need to call a tow truck. Most auto shop will eat the tow charge, if the work is done there; because it's going to be an expensive fix. An oil change isn't going to fix this. You've got coolant leaking into your engine oil - that means $$$$$.
    Or you can rent a tow dolly and winch it onto that to take it to a mechanic.
    #2 BiomedO1, Feb 11, 2025
  3. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Dreaded frozen white foam? Really?
    It's pretty normal for gasoline engines to form an emulsion under the oil cap in winter even when everything is going normally. Repeated short trips without getting up to full running temperature is a great recipe for growing them.
    And the next time the engine gets up to full running temp, the water portion naturally boils out and the remainder is closer to 100% oil.
    Now, there are other reasons why you can grow mayo in there, and some of them are Really Terrible Problems that we probably don't want to think about until an actual mechanic makes a real diagnosis.
    But so far it sounds like you might be overreacting to a natural phenomenon.
    There is no starter to disconnect- the same motor-generators that provide your electric traction are the same units that start the engine. Lose one function, lose it all.
    I would just get it started and drive it to a mechanic the normal way.
    different.eli and vvillovv like this.
  4. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    Besides, a PiP is not gonna get you more than 10 miles on EV only in winter even at (somethings very wrong ) creep home speeds. Are you within 10 miles of a shop?
    If it were me I'd get an ODB2 adapter and a phone app CarScanner, DrPrius, Carista so you can look for trouble codes, that could give you and us at least a few clues of the extent of your sometimes shaky engine issue. And possibly save you a trip to the shop, even if that's an unlikely scenario.
    different.eli likes this.
  5. bisco
    51,155
    How many miles on her?
    if you’re not losing any coolant, just drive it to the mechanic.
    If you are, it’s probably still okay to do so.
    How many miles is it?
  6. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Either transport on a trailer-tow truck.
    Or towing for a short distance at low speed with the transmission unlocked in neutral mode.
    A well-charged 12V battery is required. Turn on the start button without pressing the brakes. Shift the gear selector to neutral.
