How to Access Inverter Cooling Screen for cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by [email protected], Jun 23, 2021.
  1. Racerman15@comcast.net
    [email protected] Junior Member
    28
    San Francisco
    2020 Prius
    The inverter cooling screen on the passenger side of the rear seat has become quite dirty: dog hair, etc. I can not find how to remove the cover in order to clean it. Any assistance would be appreciated.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,166
    2,210
    Taylors, SC
    Don't you mean the battery cooler fan screen?
    bisco and Mendel Leisk like this.
  3. Mendel Leisk
    38,709
    If the screen is grubby, you should maybe dig down to the fan, give it a clean. All the ductwork too. It’s not that hard; you can just sorta follow your nose.
    @NutzAboutBolts video #21 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    has a walk-through. One thing, I would NOT pull off the rear seat as they show; you can just push apart the seat and back (just below the inlet screen) and reach through with a 12 mm socket (IIRC) on an extension, to remove the one bolt required. Don’t drop it.
    #3 Mendel Leisk, Jun 24, 2021
