How to add DRL Daytime Running Lights for a USA Prius going to Canada
Discussion in 'Prius c Accessories and Modifications' started by 3prongpaul, Feb 15, 2025.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    I'm sending a 2014 Prius C to Canada where DRLs are mandatory and not allowed to be turned off by the driver while car is drivable. On the USA Market Prius C DRLs can be turned off with the switch stalk. Looking at the wiring diagram the easiest way to force DRL on whenever car is READY is to jumper pin 19 Red to pin 12 White/Black wire (or any ground) on the Black connector G10 connected to light switch stalk under the steering column cover. This will mimic the Canadian setup, no way to disable DRL when car is being driven.
    If you want to disable DRL temporarily while car is stationary, (i.e. waiting in your car, at a drive in movie etc) you pull the hand brake BEFORE turning the car on. DRLs won't come on until hand brake is released.
    This method may work on other Toyota's. If you can get wiring diagram from dealer or repair shop with access to the information..
  2. 3prongpaul
    956
    728
    Here's how the mod looks installed with steering column shroud removed:
    MAX2 likes this.
  3. vvillovv
    vvillovv Senior Member
    4,318
    1,498
    NY
    mentioned you, and the others that have done custom batteries, that I've met or read about - in a post a couple days ago. Also mentioned your shop a couple times if they have a Denver area in their profile.
    I hope business is going well on your lot !
