(HOW TO)Add wireless charger to your base prius (for cheap)
Discussion in 'Gen 4 Prius Accessories and Modifications' started by jareza, Mar 17, 2020.
  1. jareza
    jareza Junior Member
    16
    Laredo
    Two Eco
    (edit: I tried adding pictures inside the thread but I just got broken links so I added my photos at the bottom of the post)
    Hi everyone:
    I wanted to share with you my most recent and easiest mod to my base prius.
    When I got my prius out of the dealership, I had an Iphone 7 which lacked wireless charging. I know have an Iphone 11 and I just cant get enough of the whole wireless charging thing.
    So here is what you will need
    Wireless charger pad
    12 volt socket (with inline fuse)
    Wire Taps
    a 12 volt to USB car charger (dont cheap out on with these, believe me its a hazard to use those dollar store sockets, get a decent one) I got this exact same one:
    A cheap voltmeter (not a requirement but always a good idea to have one handy to check polarity)
    Trim removal plastic tool and common sense.
    So basically you start by removing the trim piece thats in front of the armrest, you just pull that upwards and then its a matter of pulling the whole console up, its just held by clips.
    You flip it over, tap into the 12 volt outlet wires. and just run the wires up towards the front of the console.
    It took me about 20 minutes from start to finish and its something I recommend anyone to do.
    its super easy and no soldering skills are required (or wire splicing)
    if you have any questions please let me know, I wanted to add as much pictures to this thread but honestly its a really straightforward install
    https://photos.app.goo.gl/JZhRWbc6Uhqu7HyT9
    https://photos.app.goo.gl/C7ymJmq9vM7vyZMc6
    https://photos.app.goo.gl/Dmq8epwnsDY5bzSY9
    https://photos.app.goo.gl/aBhu6k8Po1GywNkB6
    https://photos.app.goo.gl/pHADAuu1bngT6UWy8
    https://photos.app.goo.gl/762MmFjSnDkmfQ3q9
    49,371
    well done!(y)
  3. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    You might be able to simplify a little with a hardwire kit
  4. DonJuan1943
    DonJuan1943 Member
    64
    52
    Northern Illinois
    Thanks Jareza! Good work!
