How to adjust headlight on Gen1 Prius
Discussion in 'Generation 1 Prius Discussion' started by 3prongpaul, Sep 12, 2017.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    To adjust headlight beam (up/down) on Gen1 Prius you need a fairly long #2 Philips screwdriver, insert throught the Dime size hole.
    Insert in the guideways until it mates with the "cog gear". As you turn the screwdriver the beam should move up or down, depending on which way you turn the screwdriver.
    The photos below from a passenger side headlight (off the car) will help make more sense of the procedure.
    #1 3prongpaul, Sep 12, 2017
    WHCSC and FireFighterHill like this.
  2. ChapmanF
    17,326
    I was sort of proud of the pictures I took here, too. :)
    -Chap
