How to average MFD MPG's
Discussion in 'Gen 2 Prius Main Forum' started by SureValla, Aug 23, 2007.
  1. SureValla
    SureValla Member
    590
    Shelton, CT
    Ok so you may or may not know that taking a average of multiple tanks MPG's is not the same thing as summing all the miles you drove and dividing it by the sum of all the gallons you've burned.
    This has been bothering me since I got my prius two months ago. Ive wanted a way to take a lifetime measurement of my car's mpg via the MFD and by calculating it the old fashioned way. I finally found out how to do it:
    Just to get our bearings lets go over what the old fashioned hand calculation is and means:
    Lifetime MPG = Sum Miles drivin/Sum Gallons Burned
    Now there are two ways to average the MFD mpg readings for multiple tanks
    Method 1: Take an average of all the MPG's of each tank
    For example say the MFD readings for 3 tanks is the following
    44.2
    46.2
    49.4
    Averaging these numbers gives you 46.6
    Now this number is NOT comparable to the old fashioned method. This is because it was calculated differently. This number tells you not your lifetime MPG but what you can expect from your next tank of gas for you're car. You might say that is what the old fashioned way is too but this is not so.
    Unless each tank is drivin the same number of miles old fasioned way and Method 1 will give different results. This is because your MPG is effected by how much gas is left in the tank (aka less fuel = less weight = better mpg).
    To correct for this imbalence I present Method 2
    Method 2: Weighted Average
    Lets stick with the previous 3 tanks mpg and add how many gallons were burned on each tank
    9.93
    9.95
    8.843
    Now add a column to your spreadsheet. This column = that tanks gallons burned/sum of gallons burned on all tanks
    so the next column will look like this for our 3 tanks:
    .3457
    .3464
    .3079
    Now add one more column and make it = Tank MFD MPG * the Weighted number just calculated for that column
    this looks like this:
    15.28
    16.00
    15.21
    Summing these numbers will give you a MFD Average MPG that is comparable to the old fashioned number!
    This gives 46.49
    (note if you know how to use the sum product this is a little easier)
    Summary:
    Averaging multiple tanks MFD MPG is not the same as the old fashioned way
    Meaning of old fashioned way: Your cars lifetime MPG
    Meaning of Method 1: What you can expect your next tanks MPG to be on the MFD
    Meaning of Method 2: Your cars lifetime MPG
    Why Old fashioned and Method 2 do not equal Method 1: Method 1 and OFW give more weight then they should to different tanks of gas based on the number of gallons burned.
    This difference becomes more obvious when you have more variation in fillup size (aka lots of small and large fillups)
    Hope that was understandable and I helped somebody get over the annoyance Ive had for the last two months.
  2. goldprius
    goldprius New Member
    My now deceased father taught me to keep a little notebook in the glovebox. Write down your odometer reading & gallons each time you stop for gas. It seems that way before hybrids, people would buy big pickups or sedans. Fill 'em way up on one tank, then stop at the first click on the next fill-up & brag about
    what good mileage they were getting...
    Sorry if that sound way low tech. But looking at six months or a year is sound.
    I have heard talk of the Prius having a bladder. I topped off today. I had almost exactly 500 miles.
    The mileage thing-a-ma-jingy said 62.7. I calculate 500/8 = 62.5 so that is close enough for government work.
    I am sure I have not helped you, since you sound more computer savvy than me!
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    I use a spreadsheet to keep track of the statistics of every fill-up. To calculate the life-time average MPG as displayed by the MFD insert a formula that calculates it based on a weighted average. As you correctly stated a weighted average is required since mileage driven varies from tank to tank. I use a weighted average based on the mileage given for any given tank and the total lifetime mileage driven.
    Once you have the correct formula just copy it down for every new fill-up.
  4. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    For years I've kept a small notebook in the side door pocket of each of my cars, and at every fillup record the date, odo reading, total $ amount & gallons purchased. This all goes into a spreadsheet to keep track of MPG, miles/week and year, and several other factors. I calculate total lifetime MPG, but what I find most useful is a column that shows the average of the last four tanks. I did this to smooth out the error due to every fill-up not bringing the tank to the exact same 'full' level.
    (I actually started writing a perl cgi version of the spreadsheet, though I haven't gotten around to finishing that yet.)
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
  6. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(morpheusx @ Aug 23 2007, 11:06 PM) [snapback]501363[/snapback]</div>
    Don't you still have to type in the information? <_<
  7. morpheusx
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(GeoDosch @ Aug 23 2007, 11:14 PM) [snapback]501368[/snapback]</div>
    all you have to type is
    Miles Driven and MPG from MFD display can't get any easier then that B)
  8. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(morpheusx @ Aug 24 2007, 08:26 AM) [snapback]501485[/snapback]</div>
    If you're entering MPG off the MFD, then you don't really even need miles driven.
    The reason I calculate it based on miles and fueling amount is that I know it's correct (within the accuracy of the gas pump meter & odometer, which I can calibrate.) I don't know how accurate the MFD is. And I've used this method on all my cars for years, most of which had no onboard MPG calculation.
    With my spreadsheet, I'm entering 4 values, though I'm also getting a lot more information from that, such as how many miles I'm averaging per day/week/year, how much I've been paying, gas price trends, cost per mile etc.
    Sure it could. There could be a link via my bluetooth data connection to automatically upload my mileage data. :lol:
  9. Bohous
    Bohous New Member
    316
    Boston-ish
    I didn't do a spreadsheet for my first year or so but recently started one just to test the accuracy of the MFD. I am doing it the old fashioned way by simply calculating each tank by hand and comparing my numbers to the MFD and come up with +/- average over time. I try to make a point to keep it as consistent as possible by filling up at 2 pips which is usually around 8 gallons. In the short time I have been doing this I have found that the MFD is generous but it varies so much tank to tank I expect that it might even out eventually. Given the argument presented by SureValla I might have to rethink this as an accurate method to test. I never thought I would take advice from a Yankee fan. :p
  10. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(SureValla @ Aug 23 2007, 06:40 PM) [snapback]501263[/snapback]</div>
    This number really doesn't tell you anything about what you can expect from your next tank, and the reason it doesn't give you the lifetime mpg really doesn't have much to do with the weight of the fuel in the tank. MPG is a ratio that tells you the relationship between miles driven and gallons used, but it doesn't tell you anything about how many miles you drove or how many gallons you used, so simply averaging the ratios only works if they are all computed relative to the same amount.
    To calculate lifetime MPG when you regularly reset the MFD you need to keep track of any of the following:
    MFD MPG at reset & gallons used for each MPG recorded (MPG * gallons = miles)
    MFD MPG at reset & miles driven for each MPG recorded (miles / MPG = gallons)
    total number of miles driven (odometer) & total gallons used (total miles / total gallons = lifetime MPG)
    It really doesn't need to be this complicated.
    If you are keeping track of both the MPG and the number of gallons, then the math gets very simple.
    So for instance 44.2 MPG * 9.93 gallons = 438.906 miles driven on that tank.
    Compute miles for each tank, add up all the miles, add up all the gallons, divide the two totals, and you have your lifetime MPG.
    44.2 * 9.93 = 438.906 miles
    46.2 * 9.95 = 459.69 miles
    49.4 * 8.843 = 436.8442 miles
    Total miles driven = 1335.4402
    Total gallons used = 28.723
    1335.4402 mi / 28.723 gal = 46.49376 MPG.
  11. morpheusx
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(GeoDosch @ Aug 24 2007, 09:43 AM) [snapback]501504[/snapback]</div>
    it still needs to know how far you drove with the current average. The miles is a significant part on calculating the lifetime avg
    click my green hybrid link below and take a look tank by tank
  12. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Danny makes a very good point. The prior tank has no relation to the next tank unless your driving conditions are almost identical.
    If things change (e.g. temps drop, or you have to climb some hills tomorrow), then the upcoming tank certainly won't match any average you've got.
    The same goes for traffic accidents. You can be driving for 20 years without an accident, and that factor often has little to do with what happens in the next mile.
  13. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(Rick Auricchio @ Aug 24 2007, 10:20 PM) [snapback]501858[/snapback]</div>
    incorrect, I am looking at this from purely a statistical point of view where the definition of an average is what you can expect the next number to be
    (dictionary.com gives this definition of mean for statistical purposes - expected value.)
    if thats not good enough just trust me Ive most likely taken way more math classes then you have : ) (no disrespect)
    <div class='quotetop'>QUOTE(Danny Hamilton @ Aug 24 2007, 12:24 PM) [snapback]501525[/snapback]</div>
    yes it does but the math is not simple when trying to compare MFD to hand calculations which is the point of my post
  14. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(GeoDosch @ Aug 24 2007, 06:43 AM) [snapback]501504[/snapback]</div>
    Actually, I enter the miles driven and the gallons pumped, and it figures mine that way, just like by hand!
    GreenHybrid allows for different ways of putting in your information.
  15. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    I also thought that the MPG shown is an average for the tank. So you would be averaging an average which would not be correct. I did what was mentioned before and keep a little note book and just record the Date, Odom, (which give me the miles driven), and gas put in to get MPG. Then the anal-yst in me kicked in and I made the spreadsheet (link in my signature). It is a compilation of a few others. I try to update it regularly if you see any mistakes. I have not had to motivation to add any macros yet.
    I had thought about doing some correlation testing with the temp data, but I figured I would also need information about city or highway driving, who was driving, etc.
  16. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    Below is a screen-shot of the excel sheet I use. The first four columns are what I enter (date, odo, $$ and gal) and the rest are calculated. The average columns (vs. tank) are for the last four entries, which is to smooth-out variations in fill-ups (i.e. not always refilling to the exact same level.) The gauge column is also calculated, so I can compare it to what my guess gauge was showing (which on mine is actually quite consistent)
    [attachmentid=10885]
    I've made no attempt to track the type of driving, since over the course of a tank it pretty much runs the gamut, unless I've gone on a long-distance trip, in which case I'll add a comment to the entry.
    If anyone is interested I'm happy to share. I also have a variation that I used on my leased vehicles that tracks how far over/under the alloted mileage you are (I'd usually turn in my leased cars just a few miles under the limit.) My online version isn't quite ready for public display.
    I've done this for most of my cars (my first version of this was on VisiCalc). It may seem overly involved to some, though as a programmer who grew up with a scientist for a father, it's just the tip of the iceberg. :D
  17. patsparks
    10,664
    567
    Adelaide South Australia
    Better than what my wife does.
    She records petrol purchased and kilometre readings each fill up but does exactly nothing with the data. Never calculates economy, nothing! She throws the book away when she sells the car.
  18. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    I keep a detailed spreadsheet and the graph files are at Paul's Prius Page. Screenshot below:
    I've discovered that accurately averaging my MFD mileage (mutiply miles driven by MPG then divide by total miles) and comparing to total miles divided by total gas purchased shows my MFD reads 1.5 miles better than reality. The MFD is more consistent than the fill-up calc (thanks bladder), but there is a bias in the number.
    With that data I can graph things such as this:
    or this:
  19. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(enerjazz @ Aug 25 2007, 12:56 PM) [snapback]502017[/snapback]</div>
    That's great how you graph MPG as a function of temperature! I used to do that for my home heating/cooling consumption, but hadn't thought of doing so for my cars. And since the Prius FC is probably affected far more by temperature due to the ICE warm-up phase, it makes perfect sense.
  20. morpheusx
    1,555
    81
    Akron, OH
    I knew I was a bit of a geek, but gosh what a bunch of NERDS!!!!!!!!!!!!!!! :D
    NERDS! NERDS! NERDS! NERDS! NERDS! NERDS! NERDS! NERDS!
    Yes I just reduced this down to name calling. :)
