How To: Change License Plate Bulbs (Video)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by usbseawolf2000, Oct 30, 2008.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I made a video to assist in removing the hatch interior plastic panel to get to the license plate bulbs. I hope many find this useful because it was not very easy to do it with just one hand while holding a camera.
    I ordered a new pair (again from Warden_JP) of these wedge type LED bulbs for my license plate. My old pair for some reason have different color temp. One was more blue than the other.
    Sorry, if it is too hard to hear me. I turned up my Metallica too loud. :rockon:
  2. Tideland Prius
    16,561
    *Moved to Knowledge Base with Link*
  3. VipAutoSalon
    VipAutoSalon Pursuing Perfection
    Torrance
  4. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Thanks for providing a preview of what to expect.
    I've been procrastinating with the replacement of one of my bulbs... knowing it could take an entire afternoon to capture enough good photos for a proper writeup.
  5. Watdawg
    Watdawg New Member
    Daphne, AL
    Very Helpful!!! I only broke one clip and the video helped tremendously! Thanks Again.
  6. kbdb61
    kbdb61 New Member
    New Jersey
    Thanks so much, your video gave me confidence to try replacing the bulbs on my own.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i see a name.. but no link or contact information of how i can get these LED bulbs... i guess i could go to a local shop and test my luck....
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Search in the seller's name on ebay. Posting the link to the auction is not good because it expires.
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I don't see why not. I am not changing License plate number or anything, simply the light bulb. If the original one died, I would have to replace it too.
  10. Xapplimatic
    Xapplimatic Intermediate level elect. tech
    Victorville, CA
    Best place to get good quality BRIGHT LED replacements:
    energyspeed... that's the website address but I can't put the part before or after that cause I'm too green in the forum.. lol but you know how most addresses start and end.. so it shouldn't be hard to find it.
    You can look your Prius up by year and it will tell you which bulbs go where...
  11. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Whew I had another nightmare last night that my bulbs burnt out and I had to do this all over again.
  12. charlietokowitz
    charlietokowitz New Member
    23
    Chicago
    How are you supposed to pull the bulb housings out once you've removed the panel?
    I pried the panel out (and i'm not sure how in hell it's going to stay in again) and spent fifteen minutes squeezing the housings and trying to rotate them counterclockwise and then pull. I even used pliers. No such luck. What's the trick? I don't want to break anything!
    Charlie
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It is CC facing the rear of the car (sit in the hatch and face rear).
  14. charlietokowitz
    23
    Chicago
    Yessir. I tried to do it from the angle of sitting off the edge of the trunk.
  15. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    And this is called progress! Holly crap what a rigama roll to change tail light bulb.Weird looking bulbs as well. In the old days it was so simple.Oh well it still has a wire going to it, witch surprises me! Hal
  16. lloemm
    lloemm Junior Member
    Charlotte NC
    I'm having the same problem. i tried pliers and wrenches, and turning in all directions but mine will not let go. i have one burned out and I'm not really wanting to get any type of ticket for it...
    any advice?
  17. talonts
    talonts VFAQman
    468
    76
    Grab the socket, push it AGAINST the housing, turn CCW 1/8 turn or so, then pull. It should pop right out.
  18. lloemm
    Charlotte NC
    Thanks! I'll try it today
  19. kyrkbymannen
    kyrkbymannen Junior Member
    Uppsala
    Thanks for posting this. I went crazy about this swedish prius, how to remove the plastic cover to get to the plate lights.
    It said in the manual "remove cover" and nothing more, impossible to know how to, and the solution was pure force! :)
  20. kyrkbymannen
    Uppsala
    You have to use force to "screw" them a quarter out.
    I managed to break one of mine, which is now fastened with duct tape.. but led turned out nice! :)
