How to Change SIde View Mirror Glass?
Discussion in 'Gen 2 Prius Main Forum' started by Cory151, Oct 11, 2012.
  1. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    Have been unable to locate Prius specific instructions on this after some clown clipped my L/H drivers side mirror (just the glass is shattered there is no issue with the rest of the power mirror). Can anyone who actually replaced the glass recommend a set of instructions specifically for the 2G?
    Thanks
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Push the top of the glass so that the bottom moves towards u.
    Stick ur fingers between the bottom of the glass & the body of the mirror......now pull the bottom of the glass towards u to release the clips on each corner.
    Bring the top of the mirror glass out towards u.
    Lift the glass up towards the sky so that the 2 hooks at the top come undone.
    That's it. Install is the reverse.
    Dylan Doxey and usnavystgc like this.
  3. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    Thanks sfv41901.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
  5. Jeffjett
    Jeffjett Junior Member
    16
    Is replacement on the 2012 side view mirror glass the same process? The mirror is heated. Thanks.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yes. Just make sure u unplug the 2 black wires.......& be careful, they are very fragile.
  7. Michael G
    Michael G Junior Member
    I have 2011 Toyota Prius Five. Driver side mirror was hit by a Lacrosse ball and spider webbed. Mirrors are not heated, but I assume the wires are there? Can I replace with a heated mirror glass just as easy as a non heated mirror glass?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    U have a gen3 Prii so a gen2 mirror will not fit.
    But yes, u can use a heated mirror glass in a non heated mirror housing & the other way around.
  9. thdoan
    thdoan Junior Member
    Dallas, TX
    Do you any store I can purchase replacement glass for my 2010 Prius. I am looking for the glass already glue on its back panel, so I can just pop the old one out, and snap the replacement in.
    Thanks
  10. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    Apart from the dealers they are available on Amazon, and Ebay at good prices.
    John (Britprius)
  11. whitmanrf
    whitmanrf Junior Member
    23
    Miami
    I have a 2013 Prius Three... the mirror attachment to the motor is a circular clip, not the bottom push-in pins and top rotating clips.
