How to change the day on Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by aaf709, May 29, 2022.
  1. aaf709
    3,862
    2022 Prius Prime
    Hello,
    I recently bought a 2022 Prius Prime (Limited). Originally I had a 2005 Prius. This means a learning curve.
    My problem is with scheduled charging. I set the Start time and Departure, but it doesn't charge. I had thought I was missing a step, but when I looked at the display, it showed that the current day of the week is Wednesday (today is Sunday).
    Perhaps I set the wrong year when I was first asked, but I have no idea as to how to change the day to the correct one. If I change the schedule to Wednesday (and it will really charge on Sunday), that will work as a band-aid. I did a search and discussions are more about the clock or from 2012.
    Has this happened to anyone? If so, how do you correct it?
    Thanks,
    Greg
  2. aaf709
    3,862
    2022 Prius Prime
    Figured it out with another search. I could access the calendar in "Meter Customize" in the settings. I had the year set as 2024. All in the manual on page 248 or so.
    schja01 likes this.
  3. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    Nice you figured it out. Even nicer that you came back and shared the solution with the rest of us. Enjoy.
    aaf709 likes this.
