How to change the dipstick tube?
Discussion in 'Gen 2 Prius Main Forum' started by Help07Prius, Oct 30, 2024.
  1. Help07Prius
    Help07Prius Junior Member
    30
    I have an 07 Prius with a dipstick tube that is broken or came out, causing an oil leak and making it impossible to check the oil level. I suppose somewhere down the line it was yanked on as the mounting bracket at the top of the tube is also broken off. How difficult is it to replace the tube and what would that process involve?
  2. highmilesgarage
    highmilesgarage Active Member
    493
    182
    Kansas City
    on a good dipstick tube there's a 10mm bolt that holds it in the manifold, once that's removed you can just pull it out. There's an o-ring down there that seals it from the engine. In your case I don't know how broken it is.. maybe some part of it is still attached down there at the engine side and you can just use pliers to pull it out. Putting it in is also easy, just insert and secure it on the manifold with the 10mm bolt.
  3. Help07Prius
    30
    The upper attachment seems to be missing and I can barely see the lower bracket, but it's not attached to anything. I'm not sure what's holding it in the engine bay but it is kind of loose and out of place. I can't see where it's supposed to be attached to. What do I need to remove to get to it?
    #3 Help07Prius, Oct 30, 2024
  4. Help07Prius
    30
    I assume the actual tube isn't broken since I can see the lower bracket, but the dipstick is actually just sticking out of the end of the tube and past the oil filter. It was pulled out somehow, maybe the bolt worked itself out. I see a hole in the engine where the top bracket would have connected and it's a couple inches lower than where where the dipstick tube is currently resting.
    #4 Help07Prius, Oct 30, 2024
  5. Help07Prius
    30
    Nevermind, the bottom connector is connected to a hose, I was able to push the dipstick tube back in but I'm missing the 10mm bolt at the top. Any idea where to buy a replacement bolt?
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,500
    Taylors, SC
    Home Depot has them in their specialty faster drawers. M6x1.0x16mm flange bolt with a 10mm hex head
    Help07Prius likes this.
  7. Tombukt2
    Tombukt2 Senior Member
    13,444
    2,418
    Durham NC
    Take your quarter drive 10 mm socket and ratchet and take one out of the fender while you're bent over the hood fixing this just reach over and take one of the fender bolts put in another one later know the fender's not going to fall off because you took a bolt
