How to change units from Mpg to kill and temperature from F to C
Discussion in 'Gen 2 Prius Technical Discussion' started by Mhd, Dec 2, 2016.
  1. Mhd
    Mhd New Member
    Amman
    Priest 2006
  2. Mhd
    Mhd New Member
    Amman
  3. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    From where was your 2006 Prius imported?
  4. Mhd
    Mhd New Member
    Amman
  5. Mhd
    Mhd New Member
    Amman
  6. dolj
    dolj Senior Member
    8,217
    4,187
    Generally speaking those are set in the factory and can't be changed. But I'm not sure if the USA and Canada share the same market build, in which case you may be in luck. But I'll leave it to the USA/Canada brethren to confirm.
  7. Mhd
    Mhd New Member
    Amman
  8. dolj
    dolj Senior Member
    8,217
    4,187
    If the speedo display works the same as the EU model, there is a MPH/km/h button at the bottom left of the MDF, but that is all it changes everything else stays in old school units. Prius MPH-kmph button.png
  9. Mhd
    Mhd New Member
    Amman
    Thanks alot. I need more than that... the speedo is changeable but other stuff mpg and tempreature are not I think I have to take on thim
