How to clean the battery cooling fan (Youtube)
Discussion in 'The File Library' started by Dan_, Aug 15, 2014.
  1. Dan_
    Dan_ New Member
    CA
    I
    Did it today and made this instructional to help others. Mine was relatively clean but I had 30 minutes to kill so figured Id check and see.
    51,759
    well done, thanks!(y)
  3. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Good job.
    If you buy a Gen III one day I hope that you do an update.
  4. Fifine
    Fifine Member
    108
    So Cal
    You did this in half an hour???! :p
    Good to keep in mind when the 12v needs to be replaced, to also clean the fan.
  5. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
