How To Clean The Purge Solenoid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pingd, Sep 18, 2019.
  1. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    I need to do the whole EGR circuit cleaning routine - including the intake manifold.
    I decided to buy a used intake manifold [ebay/$120] ... amazingly it also came with the throttle body assembly, EGR pipe and purge valve/solenoid (aka canister purge valve/solenoid).
    I also ordered a brand new Toyota EGR cooler [ebay$172] so I shouldn't have to clean much the day of (i.e. just swap in the clean parts).
    Is it worth it to clean the purge valve - or should I just buy a new one?
    If yes, would this be the recommended way to clean it?
    There are also a few rubber hoses attached ... is this the recommended way to clean them?
    "Clean with a brush and soapy water. Then use a silicon based protectant."
    #1 pingd, Sep 18, 2019
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Purge valve cleaning not necessary
  3. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    I don't know what type of gunk could get in there?
  4. Mendel Leisk
    40,582
    Yeah it's likely fine. Also, maybe just continue to use the one that came with the car? Ditto for the throttle body?
