How to - Cleaning sticky mode buttons.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bmr4life, Jul 12, 2017.
  1. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Open center console and pry up cup holder from the rear. No tools needed for this.
    Push in the tab on the connector to remove it then pry the button module out of the grayish plastic holder. Optional, you may also want to remove the gray piece so you can wash between the gray plastic and the black part that contains the cup holder. To do this you have to remove the larger Phillips screws and pry the holding the tabs.
    Remove the two small screws from the bottom of the module (already removed in my pictures) then pry the bottom base off.
    Remove the control board.
    Pry the individual buttons out. May need two flat head screw drivers for this, one of each side of the button. Wash the buttons and frame you just removed them from. Don't wash the control board.
    Dry and reassemble everything in reverse order.
    #1 Bmr4life, Jul 12, 2017
    52,371
    well done, thanks!(y)
  3. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I need to do this. Great write-up and pics!
    Thanks!
  4. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    Just finished this procedure. Worked like a charm. Thanks.
  5. Sjri
    Sjri New Member
    Dartmouth
    2014 Prius v wagon
    I just got a Prius V yesterday and noticed I couldn’t get the eco mode button to work. I used your procedure and it worked great thanks!
  6. restcure
    restcure Junior Member
    Ontario, Canada
    2014 Prius v wagon
    Touring + Tech
    Excellent write up. Thank you.
  7. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    Timely post and good job! I just discovered that my mode buttons are sticky.
    I'll have to say that the mode buttons on the v (wagon) are in a really poor location. Seems really susceptible to 'spillage'. (y)
    Does anyone get creaks in that area? I have a console creak in the cupholder area and it drives me nuts sometimes.
    lvidmar and Mendel Leisk like this.
  8. Etinmot
    Etinmot New Member
    2013 Prius v wagon
    Brilliant write up and procedure. Stupid design - placing buttons right next to the cup holder, practically begging for soda and coffee to spill onto the buttons.
    Pv14driver and Mendel Leisk like this.
  9. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    “Pepsi Syndrome”
    Pv14driver likes this.
  10. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    That's nothing compared to the P8.
  11. George W
    George W Senior Member
    911
    514
    San Antonio
    The great devaluator which will lead to early demise of these functions. Can you imagine 10 years of foreign material?
  12. lvidmar
    lvidmar New Member
    Eugene, OR
    This is great! Thank you!
    Now I'm thinking about a cup holder that is about 3mm bigger so my Hydroflask will fit. I needs my coffee.
  13. kim.mpls
    kim.mpls Junior Member
    22
    Minneapolis
    Excellent directions! Just bought a 2012 that was stuck in Eco and EV-- not sure what that did to the car. I was able to clean this up and they work like new now!
  14. Air_Boss
    4,220
    1,188
    New Yawk
    You just had to exercise your right foot a bit more.
  15. Shrug
    Shrug Junior Member
    CA
    Rad, thanks!
