How to connect stock bluetooth wiring?
Discussion in 'Gen 2 Prius Audio and Electronics' started by repnatl, Nov 4, 2016.
  1. repnatl
    repnatl Junior Member
    49
    24
    US
    On my 07 prius II I've already got the overhead console with Bluetooth microphone and amp, steering wheel controls and 09 package 8 mfd with nav and Bluetooth. I'm not concerned with the nav portion. I'm trying to find the wires to hook up the stock mic. Where can I find the MACC Brown wire, MIN+ green wire and MIN- red wire? I've already added the pins to the plug but need to know where I can wire these in so that the mic works? I have the wiring diagram and it says these go to the IB1 connector but where is that in the car? I'm very tech and mechanic savvy so the more details the better. My wife has an 06 package 8 so worst case I can take hers apart and see but I'd rather try here first lol.
  2. repnatl
    49
    24
    US
  3. dolj
    dolj Senior Member
    7,653
    3,867
    Wellington, New Zealand
    That is not a question that has come up very often, if at all.
    You may need to spend $15 for a two (business) day subscription (if you time it so your sub starts on Friday, you will have till midnight Monday, so effectively 4 days) to Toyota USA's TIS (Technical Information System) which will give you access to all the manuals and information you need to figure this out. There is a manual that has all the plug specs, descriptions and locations. @ChapmanF knows his way around all the tech manuals, and if he has time, I'm sure he will chime in to give you pointers.
    Sorry not to be able to help more.
    repnatl likes this.
  4. repnatl
    49
    24
    US
    Awesome I'll Def look into it. I've seen this plus how to install nav done before. Got a package 2 prius for $500 so I'm adding the other luxuries lol.
  5. ChapmanF
    15,614
    Did you get the wiring diagram in book form, or are you viewing it on techinfo?
    In the book form, you should be able to flip to the section showing all the connector shapes, find IB1, and see a cross-reference page number to one of the location&routing pages where you will see it called out on a diagram of the car.
    If you're viewing online, just click the IB1 you see in the diagram (starts blinking red), then click the orange info button in the lower right corner, takes you to a page showing the connector shape and part number. Click the "position of parts" link on that page, and you'll get the diagram of the car, showing the position, with IB1 again blinking red.
    -Chap
  6. repnatl
    49
    24
    US
    Haven't gotten to it yet the holidays had me running around crazy. Prob next weekend or so. So many leftovers I can barely move to go track down wires lol.
  7. repnatl
    49
    24
    US
    Never could get the wiring right so looking for other alternatives.
  8. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    With this device you can bluetooth the music from your phone through the radio station 87.9
  9. repnatl
    49
    24
    US
    Ended up adding a double din android head unit to solve the issue.
