How to convert cassette tapes to CD
Discussion in 'Fred's House of Pancakes' started by jkash, Nov 27, 2005.
  1. jkash
    jkash Member
    889
    West Hills, CA
    Hi all,
    We have a lot of audio cassette tapes at home and I would like to convert them to CD's so my wife can play them in her car. I'm sure there is someone in PriusChat land that knows how to do that. I have a Mac running OS 10.4.3 Tiger.
    Thanks in advance.
  2. roach52osu
    roach52osu New Member
    200
    Dublin, Oh
    edit ... NM just saw you were using Mac.
    Thanks,
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well the tough part is getting an adapter from your tape player to the line in on your Mac. after that, Audacity is easy to use and free.
  4. joelparks
    joelparks New Member
    82
    Bedford, MA
    Why did you edit that? Did you post instructions for idiots like me using Windows XP? I've got the same question but no Mac
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ummm... Audacity works for either platform...
  6. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    I too have many old cassetts but will never transfer them to anything because of the quality. Tape is bad. You may not care about the quality. If I were to convert mine to CD I would hook up an old tape player's RCA outs to-headphone mini jack adapter and plug in to your sound card's line in. Then comes the not-so-fun part. Using any recording software, start the recorder and then the player. Of course make sure you clean the heads on your tape deck first. When you are done with both sides of the cassette then use a wave editor to cut each track and save them as the highest quality your OS supports (WAV or AIF for PC and I think AIF for Mac). You may want to use a filter called Normalize before saving in order to keep a more consistant volume level. Look at the files of a pre recorded CD to see how they name the tracks (01_track name). Then, the most important step is to burn them to CD with Toast or iTunes for the Mac. Make sure in your burner software that you set burning to an audio CD in the preferences so the program can convert your files to the correct format to play in a CD player.
    Now, repeat that for each tape. :eek:
  7. roach52osu
    200
    Dublin, Oh
    Yes it was a tape drive for XP, here it is but the other option would probably be better since you wouldnt have to buy or install components.
    http://www.thinkgeek.com/computing/drives/7a8d/
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Piece of cake. I transferred all my reel to reel tapes and vinal to CD on a Mac. Get Roxio Toast. It has a converter from analog to digital. Griffin has an input device that does mini plug to USB if you need it. My old Mac that I use for this has a audio input. If you want to do vinal you need a pre amp for your turntable. Mac's have always had the ability to do audio.
  9. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    That's way too much money for the low quality of cassette tapes and then you are saving as MP3 but at what rate?
  10. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    Here's the software that will do what you want http://www.roxio.com/en/products/emc/index.jhtml
    You can use the line input to your PC to capture the audio from the tape or LP
    Beware of the label creator option though! If you wish to label your CD's for use in a slot load player (the kind in the Prius) DO NOT USE PAPER STICK ON LABELS they have a habit of comming loose with the temp variations and can jam (re: expensive) in your player. If you have a compatable printer, you can use ink jet printable CD blanks, otherwise use a Sharpie pen to label...
    This one and others have the ability to clean up tape noise, record scratches, etc. not perfect but it does help...
  11. Mystery Squid
    Mystery Squid Junior Member
    Just download all the good songs from LIMEWIRE...
    :ph34r:
  12. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    eh, I am old school. I have a SONY® CD burner, and a mixer, where I can mix tapes, 8-tracks, records, mini discs, dvd audio, cd audio...and a Light Scribe to burn the label on to the disc...
  13. naterprius
    naterprius Senior Member
    1,843
    Okay, this thing is just plain awesome. I wish I had known about it before I got rid of all my tapes.
    Nate
  14. Mystery Squid
    :lol:
  15. HeuristicsInc
    HeuristicsInc New Member
    29
    Maryland USA
    Actually, I read a review online somewhere that said that this thing isn't worth the cost. They recommended doing what somebody ... aka007ii said instead.
    -bill
