how to defeat panic button on smart key remote
Discussion in 'Gen 3 Prius Technical Discussion' started by tedjohnson, Feb 15, 2011.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Has anyone found a way to defeat the stupid panic button on the remote? In the past I have poured glue into them, Popped the red thing out, etc , but this is a lease and I might well turn it in in a few years and do not want to physically modify the smart key, but twice in the last week it has falsely triggered by getting pressed by the other keys on my keychain as I sat in the house. This must be a common problem, since I had to defeat the same button on 2 other cars I had. I am wondering if there is a software fix to have the receiver in the car ignore the panic mode. Any ideas? Thanks.
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Tape something hard over the outside of the fob over the button? I don't feel like taking mine apart right now to see what type of button mechanism it has (eg a surface-mount type switch versus a membrane-type key where the button itself connects two traces on the PCB). If it's the membrane type with just copper (and no switch), you could also put some tape or something non-conductive over the copper traces on the inside to prevent the key from touching the PCB, thus completing the circuit.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The easiest way I found is to simply put the FOB in your pocket with the buttons facing your leg. It works well without any modifications.
  4. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    The panic button function can be disabled using TechStream. If you were local, I'd be happy to do it for you, it only takes a few minutes.
    Maybe you can convince your dealer to do it for you. Next time you are in there for something else, they will probably do it if you ask nicely.
    WE0H likes this.
  5. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    I had my fob apart to replace the battery. (Remove the mechanical key, slip something into the slot and gently pry. Do it over a table so you don't lose any pieces. DAMHIKT)
    There is a rubber membrane over the circuitboard that acts as a return spring for all 3 buttons. The actual switches are real surface-mount components with clicky things inside.
    What that adds up to is that I just saved you the trouble of taking the fob apart just to find out that there's no easy way to do what you want. It's probably easier to get a different kind of key ring. Myself, I carry the fob separately with the other keys in a leather case. Having the fob separate makes it easy to grope in my pocket and find the unlock button by feel.
  6. macman408
    1,179
    366
    Yes, carrying the fob separately is also a good idea. I don't normally drive, so I keep the fob separate from my keys. When I do carry it, I use the small change pocket on my jeans, rather than letting the fob mingle with other keys or such items. That pouch is usually perfectly-sized for the fob. Most of my shorts have cargo pockets, so the fob can live in those during the summer months. Other creative methods of attachment might be found too - for example, attach it to your shoelaces (after all, you don't need to touch the fob); hopefully the sensors both outside and inside the car can pick it up in that unusual location.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I won't disable my fob's panic button. I use it especially in larger parking lots as the honking helps me remember where my car is parked. I read an article that suggested keeping the extra FOB by your bedside in case you hear unwelcome noises of someone breaking into the house; press the panic button to honk the horn in hopes of scaring someone away. Hey, old people get insecure. lol...
    Here are some more panic button ideas from eHow: How to Keep Safe Using a Car Panic Alarm | eHow.com
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Sounds like a useful feature! UK spec fob doesn't have it...
  9. Much More Better
    Much More Better Active Member
    655
    163
    My fob is separate from my keys. But not because of accidental pressings.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    You mean, I'm not the only person that accidently presses the panic button? :blush:
  11. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Open the fob (it snaps apart to replace the battery) - you will see the spot where the 'Panic' hits the green circuit board. Place a small piece of tape on the green PCBA the size of the panic contact.. Pretty easy.
  12. pEEf
    720
    577
    Berkeley, CA
    I know this is the Gen III forum, but I wanted to remind those Gen II people (like me) that peruse all forums, that the Gen II fob does not snap apart (that I know of).
    Don't want anyone to break their fob!
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I have a Keyfob "Jacket" for my Non-Smart Key fob on my Honda Fit. I notice they offer them for Toyota Prius as well.
    www.thejacketstore.com
    I've only had mine a few months, but I really like it. Adds durability, some degree of weather protection, and most importantly the slight addition of the thickness of the jacket, recesses the buttons....makes it harder for accidental pressing.
    I really hate to promote a product...and I don't know how it might work with a "Smart Key" fob....but they do offer them for The Prius...
    I'd be curious if any Prius owners have one???
    PS:
    Also I picked mine up at my dealership...so I can't really vouch for the company itself. I did not order mine direct...
  14. priuschatter2
    priuschatter2 Junior Member
    Another low-tech solution: examine your key ring and see which key(s) is pressing the panic button. In my case, it was the bike lock key. It was possible to reposition that key (it has an off-center key ring hole) so that it couldn't depress the panic button. Also, I use a 1/2" ring, which limits the keys' ability to hit the button.
