How to determine a distance to a city which is not the final destination?
Discussion in 'Prius v Technical Discussion' started by archiveman2977, Jun 5, 2014.
  1. archiveman2977
    archiveman2977 archiveman2977
    49
    Central Texas near Austin
    2013 Prius v wagon
    Is there a way to determine the distance to a city on the NAV route that occurs before the final set destination city?
    Thanks, Archiveman2977
  2. jae
    jae Junior Member
    16
    Philadelphia, PA
    2013 Prius v wagon
    You can add more than one destination to your route. I believe the nav will just show the time and distance to the next destination. I don't know if you can toggle between the two easily.
  3. GerryL
    GerryL Master Model Railroader
    170
    22
    Minneapolis, MN
    How do you add more than one destination to your route?
  4. jae
    jae Junior Member
    16
    Philadelphia, PA
    2013 Prius v wagon
    Add one destination, let it calculate the route, and click ok. Add a second destination, it will ask if you want to add it to the current trip.
    GerryL likes this.
  5. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    You don't even need to add them in the order the fall, as you get to pick where the new destinations go into the sequence during the process. So last first, last last, it doesn't matter. All that matters is that you place them in the right order.
  6. GerryL
    170
    22
    Minneapolis, MN
    Thanks!!
