How to disable door ajar light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by themadbluebird, Mar 4, 2019.
  1. themadbluebird
    themadbluebird Junior Member
    Grand Rapids, MI
    I have a 2007 Prius with 185,000 miles. The back door handle is getting kind of janky and sometimes it doesn't close quite hard enough to tell the car that the door is closed, thus leaving the "DOOR AJAR" light on. This isn't an issue except that it drains the 9V battery, especially if I'm out of town for a while.
    Is there any way I can disable the "DOOR AJAR" light on the dash to prevent the 9V battery from draining?
    52,363
    probably have to find the connectors in the hatch and wire them together. doesn't the dome light stay on as well?
  3. themadbluebird
    Grand Rapids, MI
    I leave the dome light permanently off for the same reason. Thanks for the response--I'll see if I can permanently connect them.
