How to disable parking brake?
Discussion in 'Gen 2 Prius Main Forum' started by UncommitedPriusOwner, Sep 10, 2022.
  1. UncommitedPriusOwner
    UncommitedPriusOwner Junior Member
    Ur Moms House
    My parking brake is engaged and i want to unengaged it the pedal ain't doing nothing. So how do I remove the parking brake?
  2. Mendel Leisk
    40,575
    Repair Manual info attached.
    There's play adjustment at the pedal and at the drum, so hopefully with one or both of those you can release it. And diagnose.
    Do you use the parking brake regularly?
    Where are you btw, salt-belt?
    UncommitedPriusOwner likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I guess the question is whether both rear wheels are locked or just one.
    If both, then probably the cable between the pedal and the equalizer is seized in its sheath. If so, then I'd just cut or disconnect the cable at the brake end of the sheath, at the equalizer. This should release both rear wheel brakes. Replace bad cable when opportunity arises.
    #3 TMR-JWAP, Sep 11, 2022
  4. UncommitedPriusOwner
    Ur Moms House
    I dont regularly use the brake
    Ohio
  5. UncommitedPriusOwner
    Ur Moms House
    Ok, so the brake is disabled but anytime I put the car in gear an alarm goes off the entire time it is in gear until I put the car in park
  6. ChapmanF
    17,326
    I can't quite make out the location from your profile, but if you are in one of the areas where Gen 2 came with drum brakes in the rear, those do rely on regular use of the parking brake to keep the normal service brakes in adjustment.
    douglasjre likes this.
  7. UncommitedPriusOwner
    Ur Moms House
    Yeah I have drums
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,962
    1,911
    NJ-USA
    Any warning lights or messages on the dash? Does the dome light work correctly?
