How to disable the Prius "Artificial Engine" sound?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by chinito77, Nov 11, 2012.
  1. chinito77
    chinito77 Member
    84
    35
    Yamaguchi, Japan
    I know this may sound rather selfish or careless but I really dislike the "Artificial Engine" sound that my 2012 Prius makes. I'm a very cautious driver and don't plan on running over people but that fake engine sound attracts more attention from pedestrians...in a bad way, than I like. Does anyone know how to disable it? Is it a DYI thing or should I take it to the dealer?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Dealer won't do it.
    There are 2 ways to disconnect it. It's ion the driver side frame rail.
    1) if u have small hands, reach behind the driver headlight till u get to the VPNS (Vehicle Proximity Notification System) & the wire harness is on the bottom of the speaker.
    2) put the front end on ramps. From under the driver side, there is a plastic cover that has a small round hole in it. Remove the 10mm bolt that is attached to the bumper, pull the cover down & u will see the speaker.
    peterjmc likes this.
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Has anyone figured out how to play a different sound file? Maybe an idling big block V8 with a lumpy cam? Then again, maybe that little speaker isn't the best for reproducing bass.
    DogDaze, striker308 and chinito77 like this.
  4. chinito77
    chinito77 Member
    84
    35
    Yamaguchi, Japan
    Thank you sfv41901, I will try it this weekend!
  5. Adam Leibovitch
    498
    102
    Like the smoke moster from Lost
    BornPriiOrDie and SLRSLY like this.
  6. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    1970s F1 Cosworth DFV V8, Matra V12, or Can-Am Traco Chevy V8 doing a burnout while leaving the pits.
  7. bisco
    49,492
    what sound?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The space ship sound.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I like the sound. :p
  10. gliderman
    gliderman Active Member
    751
    223
    The theme from Jaws.
  11. dhendriksen
    dhendriksen Junior Member
    57
    I don't think my 2010 does this...is it supposed to?
    Droid RAZR HD MAXX
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Nope. It is new for 2012.
  13. Aquos
    Aquos Junior Member
    49
    houston tx
    real easy to do. just use a stubby phillips and flat head screwdrivers. remove the little plastic panel under the front of car, in front of drivers side front tire. Then you will see a speaker looking thing . the white plug is hard to unplug.
    good luck
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Nope. This only started in 2012 +
  15. Adam Leibovitch
    498
    102
    I love it. It freaked out this skin head in an alley-way the other day. WIN
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If it was a true skinhead then you should have defeated the noisemaker...... *looksevil*
  17. ETC(SS)
    6,555
    FWIW....I don't consider it to be selfish or careless to disable the VPNS. However (comma!!) if you squash somebody's little crumb-snatcher and the sniveling, bed wetting attorneys find out that your (*) ah.... safety feature has been (*gasp!*) disabled??!!
    :eek:
    What I would do is remove the speaker, and very carefully (or UN-carefully) overload it, and then try and put everything back together as if nothing ever happened. Take it in and document a complaint against the system.
    Then repeat.
    That way...you're DOCUMENTED to have tried to fix this chronic problem.
    A snipped wire?
    You did that. (Sorry Mr. President, but it does happen sometimes)
  18. bisco
    49,492
    now etc, that sounds perfectly devious.:D
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Haha...I like this
  20. Air_Boss
    3,952
    1,083
    New Yawk
    The Matra....
    Sure to scramble skinheads everywhere.
