How To Drive A Prius
Discussion in 'Gen 2 Prius Main Forum' started by Rascal, Jun 13, 2008.
  1. Rascal
    Rascal New Member
    37
    Suburbia, Pa
    I thought this could be a valauble thread. I am picking up my Prius next week and have been enjoying this forum immensely . I have viewed many experts and seasoned Prius owners comments and have learned a whole bunch of good information. My question is: WHATS THE BEST WAY TO DRIVE A PRIUS? Let me clarify...when should I use the "brake" button?...can I coast? ..is it advisable?......should i start fast to get up to speed then ease off? Let's limit to the TOP 3 money saving suggestions while driving. Thanks!
  2. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    You realize your going to get hammered with people saying you should have searched instead of thread these questions?
    But, to answer your Q's...
    Brake button? Never heard of that.
    * Try to NEVER use your breaks, by gliding and coasting(yes, coasting is OK, but gliding is better), that means you must practice anticipatory driving.
    * Briskly accelerate to your top driving speed then glide(if under 40mph) or put on your cruise control(if over 40mph).
    * Drive the speed limit.
    These practices will maximize your Prii driving, in respect to best MPG (imo)
    Next time search more before threading. These Q's are addressed all over PC!!!
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Oh boy...hope you like worms...you just opened up a HUGE can of 'em!!!
    There is the:
    1) Just drive it crowd--not an unreasonable perspective if you don't care about achieving above average fuel economy.
    2) The Hypermiler crowd--pulse & glide, never touch the brakes, don't take the highway, pump your tires up to 184 psi!
    3) The learn to drive 'casual' crowd- Moderate acceleration from a stop, plenty of following distance, anticipate stops and slow downs, don't speed, combine short trips.
    I'm more of a number 3 with #2 tendencies...and getting worse.
    But my advice will center more around #3 for the new driver.
    "Brisk" acceleration, IMO, is not the most efficient..I aim for 1850rpm...but you'll have no way to know where that is...so just keep acceleration about normal...the engine shouldn't be racing but you shouldn't fall behind other traffic until you get to about 25-30mph. Let's call this "Moderate" acceleration.
    All the other stuff under #3 above is VERY important. Back off of other cars...leave several car lenghts. See a read light 1/2 mile ahead? Slow down to a glide. As Wayne Gerdes likes to put it drive as if you have no brakes...it's best to coast to stops when feasible...car slows to turn in front of you you should have enough following distance to avoid a complete stop.
    It's about conservation of momentum.
    B-mode---if you really want something to put you to sleep look for Hobbit's b-mode article. But the short and sweet is this...don't use it. It's OK to use it on very long steep mountain descents if you really dislike using the brakes...but otherwise forget it's even there.
  4. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Drive your new Prius as smooth as you can. No jackrabbit starts and don't jam on the brakes too much unless you really need it in an emergency. Maintain a constant speed on the highway and try to keep your speed below 70 mph to get great mpg #'s. Hope you get your Prius soon. Regards.
  5. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    1) Tailgate semi trucks --Rarefied air does wonders for Prii MPGs. A couple of feet behind at freeway speeds should produce the best mileage.
    2) Premium fuel only --Hey, if it's "premium," it must be better, right?!
    3) No Fat Chicks! -- It's a proven fact that less weight in the car is better for MPGs . . .
    and with only slender cute chicks, you will also save more gas by slowing down and enjoying the company.
    (can of worms? Ooohh yeaahhh. :fear:)
  6. racerbob
    racerbob Member
    138
    S Florida
    :welcome:
    I agree with everything Prius Envy said except the "Premium fuel only". Make sure you have a "clear shield" covering your front end or the rock chips from drafting will be severe. :eek:
  7. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    I wouldn't use premium gas, it may cause the engine to over-heat, and it's a lot more expensive. Premium is for high performance engines. The Prius engine is designed for use with 87 octane. I also wouldn't tailgate a semi - my brother was a truck driver and said that is very dangerous.
    If you are on the hi-way, in light to no traffic - use the cruise control. In the city I accelerate quickly to speed then keep my foot very lightly on the accelerator.
    I use the brake mode in the winter time in icy conditions. It "applies" a light brake to the wheels as you approach an intersection. Of course you have to anticipate your approach and take your foot off the accelerator a little earlier so as to maximize the effect. With practice it will start to work for you.
    All the other suggestions are good.
    Buck
  8. efusco
    19,891
    1,196
    Nixa, MO
    Guys, SPE was joking on all 3 points...mostly.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    I think Evan may have overstated the tyre pressures too, never pump your tyres over 180PSI or the maximum pressure on the sidewalls which ever the lesser.
    -I'm from the accelerate from a standstill like you are racing for the title camp. Never let another car beat you off the lights. I'm not joking.
    -As soon as you get up to the speed limit start slowing for the next red light. I try to time my arrival at the light or the tail end of the stopped cars just after the light changes so I minimise my reduction in speed. If you have to stop use the frustration of having to stop to motivate a quick start. This is vital.
    -Never follow anyone, maintain a clear space in front of you so you drive how you want not how some wally who has no idea wants to make you drive because you are too close.
    I know you said 3 but I forget who it is has a very big magnet on their pre-2004 Prius to hitch rides on trucks, give that a go if you like.
    PS, I like the no fat chicks idea but I know some very entertaining chicks who are carrying a little beef. I like to keep my wife and son out of the car, just dead weight really.
  10. chrisspaulding
    556
    24
    Kentucky
    Hilarious!!! thanks for the LOL
  11. hill
    8,813
    Evan, would it be cool, or what . . . if we had just one more sticky:
    The templates:
    Here, you could cut and paste the answers to all the ad nausium Q's ... better mpg's the 'B' position, how to answere the naysayers, pro's con's of leather, gas squirtin' out of that dang blader, dead battery etc etc.
    A great meeting for all the rescuers and enablers :D
  12. Sufferin' Prius Envy
    3,998
    Three more 'helpful' hints . . .
    1) Never brake for small animals -- Small animals, especially squirrel- or kitten-sized ones really can't do any damage to a Prius.
    2) Only swerve for children in the road -- As long as you take some sort of evasive maneuver, if you hit the kid . . . not your fault.
    3) Blow through stop signs and red lights -- Hey, everyone else does it, so why should we Prius drivers take the hit on our comparative MPGs.
  13. patsparks
    10,664
    567
    it does mess up the aero though.
  14. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    There are a bunch of jokesters on PC, huh? Just one tip: make sure you buy SuperWhite. They get better mpg's
  15. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    < There are a bunch of jokesters on PC, huh? Just one tip: make sure you buy SuperWhite. They get better mpg's >
    1. Dirt interferes with the aerodynamics.
    2. White and black hold the most dirt, other colors hold less, Driftwood the least. Proof: I've rarely ever washed my Driftwood, and I never see any dirt on it. I've had almost every other color car, and every one of them has shown lots of dirt.
    3. Therfore, Driftwood is the only color that dirt doesn't stick to, so with better aeordynamics, Driftwood gets the best MPGs.
  16. richard schumacher
    7,664
    1,046
    United States
    Don't use "B" in ordinary driving! It reduces MPGs. It's only there as an alternative to riding the brakes on a long downgrade. There's no city in the US where you need to use "B".
    Don't speed. As with any car MPGs fall off fast above 65 MPH or so.
    Driving technique short-path zen:
    - Accelerate briskly (this makes most efficient use of the engine)
    - Gliding (no arrows on the "Energy" display) is better than coasting
    - Coasting is better than braking
    - Braking is better than stopping
    Check tire pressures at least monthly. Also, many people inflate the original tires to 42/40 PSI front/rear because it noticeably improves MPGs, but it does make the ride and handling harsher.
  17. Doc Willie
    1,717
    144
    Out there, somewhere
    San Francisco? I lost a clutch on one of those damn hills.
  18. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Consider turning off the display on your first drive off the lot, till you get home. For a noobie, there may be too much going on in the display, which will distract you from watching the road, which may cause you to hit my Prius.
  19. stedman98
    stedman98 New Member
    Virginia
    Okay, how does one "glide"?
  20. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I think there's a sticky at the top of the fuel economy forum that answers your questions... but what an entertaining bunch of answers!! I'd probably get a lot better mpg if I hadn't gained those 15 pounds in the last year.
    I've always said white cars get better gas mileage... they are cooler so the AC works less, not much, but I'm sure there is a quantifiable effect. And I don't mind long regen runs up to the stops in the summer, that electric AC compressor will suck your traction battery state of charge down pretty fast initially... don't be afraid to leave the AC on auto at 80 or 82 degrees, that keeps me cool enough, but make sure the AC does not start blowing heat if your solar sensor left-front inside windshield gets in the shade from a cloud or something, I've noticed that happen before.
