How to drive uphill? Prius battery drains quickly
Discussion in 'Gen 2 Prius Main Forum' started by McNuilty, Jul 13, 2021.
  1. McNuilty
    McNuilty Junior Member
    24
    Netherlands
    Business Edition
    Hello,
    In June I went to France to drive the Route des Grandes Alpes (around 17 large mountains you climb between 1000m en 2500m high) and I noticed at the first hill that my Prius really struggles going up.
    At first I drove very slow uphill hoping this is best for the battery (battery went quickly down from blue area to 2 bars, I drive around 30km/h uphill constantly). The engine was very loud. The first large mountains (1000-2000m high) this went alright. At one point I heard the battery fan blowing very loud and started worrying about the battery. The battery fan started blowing mainly going downhill (I used "B" to break on the engine) and the battery goes from 2 bars to full relatively quickly.
    At one point though the car started to not be able to accelerate properly + the battery fan was full throttle so I parked and I let it cool down.This was just after coming down one hill. After letting it cool down 15 minutes the car drove fine again. This didn't occur again (this was halfway down the trip). Temperature outside around 30 degrees
    On the next mountain though the car went down to 0 stripes on the battery, I parked it on the side and the car charged the battery back to 4 bars in like 5 minutes.
    On the other mountains I changed my "tactics" and instead of "crawling" up the hill I accelerated more to around 40-50km/h when possible. The battery stayed more in the blue for the remainder of the trip.
    The car: 2006 Prius
    360.000km on the clock
    Battery changed in 2018(for a used battery)
    On the trip (around 3000km, of which 700km mountains and 2300km mainly highway) I have used 1.5L of 5w30 castrol magnatec oil (normally 500ml oil consumtion per 5.000-7.500km)
    I have the feeling my battery is dying (again) but I want to get as much life out of it as possible. In the Netherlands where I live and commute, the roads are flat and the battery is doing fine here (never in the purple and hardly in the full green).
    I want to drive through the Alpes again in august and wonder if anyone had a similar experience as me and what is the best way to drive up and down the hills (should I use "B" and break on the engine?).
    What to do when the battery fan starts blowing loudly? And should I drive slowly up the mountain or accelerate more?
    #1 McNuilty, Jul 13, 2021
  2. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Rent a different car for the Alps trip. You have a flat land car now- enjoy it for what it is. When the cost of rentals feels expensive, it's time to get a new battery instead.
    B mode is a very good way to descend mountains. It places less stress on the battery and dissipates more energy as noise from the engine. The car can sustain that all day long. And of course it allows you to keep the service brakes from overheating.
  3. cthindi
    cthindi Member
    177
    85
    Connecticut
    I think it is just old HV battery. I had similar experience with my 2005 Prius. I could though manage to get another 2 years out of HV battery without codes. You could use Prolong system for extending battery life some. ( I did not use it. So I do not have any personal experience with that.)
    What I did on similar trip later was to turn AC OFF on climbs and Turn it ON and FULL COLD on downhills and use B mode once the battery is full.. That way you can somewhat try to balance out battery usage. If you know you are going to have major uphills coming up, you could try to force charge the battery just before climbing..
    Aaron Vitolins likes this.
  4. privilege
    privilege Active Member
    659
    169
    Birmingham
    stopping while hot is bad, unless it's over heating. it's better to drive faster with air flow than crawling (30khr is freaking slow!) and you're generating a lot of heat with b very little air flow.
    user the HVAC so that the battery intakes cold air.
  5. ChapmanF
    17,348
    At the bottom of everything, you have a 57 kilowatt (76 horsepower) car. The battery can contribute some additional power for bursts of acceleration, short climbs, and so on, but that capacity is finite. On a longer climb, if you are climbing at a speed that physically requires more than 57 kW, the battery charge will drop, and when it drops to 40% actual (i.e. as shown by an OBD-II reader, not the dash bar graph), the car will stop using it, and you will complete the climb with only the 57 kW from the engine, which will limit you to whatever speed 57 kW can give you on that grade.
    I've never driven in the Alps; my closest relevant experience is on Afton Mountain in Virginia, when I was driving my Gen 1 (which had a slightly less powerful version of the same engine, 52 kW).
    When driven by me, the car could always complete that climb without any noticeable change of behavior. One time, I let my sister drive, and she took the same ascent at around 130 km/h. I was sitting in the passenger seat watching the battery SoC on the ScanGauge steadily tick downward, and it was just above 40% when we reached our exit. Another km and my sister would have found the car suddenly slowing and unable to climb faster than a 52 kW rate.
    By the way, when the engine is at maximum output, it will sound loud, but it is in no danger. The engine control module knows its maximum output and its maximum safe rotation rate and will not exceed those. If you find the speed at which you can climb an Alp using only 57 kW, you can maintain that rate of climb all day, with the only concern being to watch the engine temperature, and back off or take a break if its cooling isn't adequate. You will at that rate be putting little net demand on the battery (and on the descent side, B mode and judicious use of the friction brakes should protect the battery from heavy charge rates).
    In any non-plugin Prius, the battery is only there to buffer short-term peaks and troughs in power demand. For any longer known situation like a sustained climb, you'll have good results if you choose a speed where the engine is supplying substantially all of the power needed, and the battery is more or less resting at its preferred 60% state of charge.
  6. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    I got one of these packs and it was a game changer: Toyota hybrid battery upgrade pack; NexPower Energy Felt like I was driving a brand new vehicle first time I did mountain climbing with it.
    Also getting an obd2 reader and using a phone app like OBD Auto Doctor app so you can monitor the RPM and keep it at around 3500, which is where the most engine power / efficiency exists.
    Here's buyers guide for an OBD2 device: Hybrid battery diagnostic and repair tool for Toyota and Lexus
