How to fix a Prius 2001 dead speaker
Discussion in 'Generation 1 Prius Discussion' started by Lorenxo, Feb 9, 2010.
  1. Lorenxo
    Lorenxo New Member
    Albany, CA
    2001 Prius
    [FONT=Georgia, Times New Roman]I have a 2001 Gen I Prius, and the right rear speaker has quit working. I can get to the underside of the speaker from inside the trunk but there doesn't seem an easy way to get to the wiring. Any ideas about how to diagnose and fix the problem?[/FONT]
  2. Patrick Wong
    18,200
    6,475
    Seems likely that the speaker has failed. Can you access the speaker mounting hardware? If yes, then remove the hardware holding the speaker to the shelf, and then you should be able to access the wires leading to the speaker.
    Once you have removed the speaker you can look at it. If it has not obviously failed based upon visual inspection, use an ohmmeter across the speaker terminals to see if there's continuity across the speaker coil.
    If the speaker is OK, then set your multimeter to AC volts and measure voltage across the wiring connectors when the radio is on. If no voltage then you'll have to pull the radio and see if AC voltage is being output, or maybe the wiring is bad.
  3. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Lacking an ohmmeter etc., the more rudimentary way to confirm that a speaker's voice coil is intact is to connect it to a 1.5 volt battery. If the speaker makes no sound its 'fuse' has blown.
  4. Lorenxo
    Lorenxo New Member
    Albany, CA
    2001 Prius
    Thanks for the tips - I'll see if I can get the speaker loose and try to test it. It is firmly attached to the underside of the trunk space with no visible wire ends (just insulated loops disappearing into the ether) and no obvious way to detach the speaker.
  5. Patrick Wong
    18,200
    6,475
    In that case it might be necessary to remove the parcel shelf trim while you are perched on the rear seat, in order to replace the speaker. Maybe you'll need to access the repair manual info at techinfo.toyota.com to see how to do this, without breaking something...
