How to fix loose window visor/deflector
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by SteveK2024, May 5, 2024.
  1. SteveK2024
    SteveK2024 New Member
    2022 Prius
    My 2022 Prius XLE Nightshade has window visors/deflectors on all 4 windows.
    The visor outside the driver window is loose from front and rattles a bit on freeway.
    Which adhesive can I use to attach the front part of deflector back to the frame?
  2. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    You'll need to heat up and peel-off the entire visor. Use a hair dryer or heat gun. R + R the tape, clean the surfaces with rubbing alcohol and reapply. Go slow and be gentle. If you break or crack something, you'll have to buy a new one or set.
    Good Luck.....
