How to Fix water leak onto passenger floor (w/ pics)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mstr2, Jul 21, 2012.
  1. mstr2
    mstr2 New Member
    Oklahoma
    Hey guys, I thought I’d help everyone out by making a how-to thread for those of you that have the leaking A/C water onto the passenger floor problem. If you’ve gone on a long trip and ended up with a pool of water on your passenger floor, you know what I’m talking about. It seems to be a common problem, especially if you live somewhere hot and have to keep your A/C on the coldest and strongest setting nonstop like I do. This is a very simple job anyone should be able to do, and takes about 20-30 minutes.
    All you need is: duct tape, a wire hanger, a few towels, and a wet/dry shop vac. (If you don’t own a shop vac, borrow one or rent one if you must, but it is a good investment if you don’t own one already).
    Step 1: Remove the plastic cover under the dashboard. This piece just pops off, there are no screws, so give it a good tug down and outward and it should come off easily.
    Step 2: Once you have that piece out of the way, reach up to the left corner of the carpet and pull it back, you don’t have to pull it very far to see the A/C drain tube.
    Step 3: Pull the tube out from the hole on the firewall, and look at the end. If there’s water dripping your clog probably isn’t that bad. Take the wire hanger, bend it straight, and stick it as far up the tube as you can, wiggling it around and pulling it out to wipe off any gunk on the wire. Try to reach the metal pipe that the other end of the rubber tube is connected to if you can, but do NOT pull the rubber hose off the pipe, it will be hard to get back on. Also, be sure to have your towels ready because you may have up to a liter of water pour out the end when you unclog it.
    Step 4: Turn your A/C on (make sure the car is fully on) and wait a minute. Look at the end of the drain tube. If it is dripping water quickly, and you don’t see much water coming from anywhere else under the dash, then you are done. I would suggest to still continue with the next steps just in case, but it’s up to you. If, like mine, the tube is fairly dry and you still see water dripping from further towards the inside of the dash, then your clog is further up the pipe and not in the tube itself. In this case you’ll need the shop vac.
    Step 5: Turn off your A/C. Now get the duct tape and wrap some around the end of your shop vac hose, gradually getting narrower, and be sure to keep as tight a seal as possible. Then wrap the end of the tape around the end of the drain tube. Keep the seal as tight as possible. Turn on your shop vac and leave it on for 3-5 minutes, or until you stop hearing water flowing. This means you’ve sucked out most of the water/gunk that’s stuck in there.
    Step 6: Now turn your A/C on and with it on, run the shop vac for another couple minutes. This will help flush and remaining gunk that may not have gotten out yet. Then turn off the A/C and the vac, and start taking off the tape. Be prepared to have a good bit of water leak out of the end of the tube when you get the tape off.
    Step 7: Put the drain tube back in the hole on the firewall, and turn your A/C on again. Look under the car and you should see water dripping under it forming a puddle, give it a couple minutes, and make sure it isn’t leaking inside from anywhere else under the dash.
    Final Step: Put the carpet back, pop the plastic back in, and you’re done! It’s normal to see a little water still dripping on the passenger floor, but that’s just leftover condensation that was outside the tubing already, and should stop within a day or so.
    Good luck! Hope this helps.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Very good write up thanks. This is why its a very good idea to clean the e-coil in the dash about once a year.
    The dealer sells a 2 part pressurized can for a diy over the parts counter for $25 or the dealer will charge $100 for that service. Your basically hooking one of the cans to the drip tube the above post shows from underneath the car and injecting the entire can of foamy cleaner back up the tube and it fills the e-coil box. It then turns into liquid and drips back out with all the gunk. Done my 2007 three times so far. Car smells real good after.
    Whenever you start to smell mold its time.
    ChrisFaehrtPrius and HaroldW like this.
  3. dpframing
    dpframing "Nobody tells me what to do, not even me."
    74
    Chester NY 10918
    2022 Prius Prime
    2 great posts. My dealer just charged me $229 to fix the leak AND my car is a 2013 and still under warranty. He said it was not covered under dirt and debris
  4. dpframing
    74
    Chester NY 10918
    2022 Prius Prime
    Hey Ed. My dealership will not sell the cleaner. Do you know if it can be found on the Web? Also, is it hard to do?
  5. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Yes they stopped selling it otc here too.
    Found KOOL IT on amazon.com. Same stuff with the one can of foamy cleaner and the special hook up hose. Its very easy to do only issue is getting the car high enough to get under it right there. The drip hose is right below the glove box and only juts out of the body about 2 inches. Right behind the rear of the passenger front tire about 2 feet in.
    I usually do it when I change the trans fluid as then the car is really high.
    here:
    as you can see there's a few choices for coil cleaner.
    Also I clean the car's front evap coil also at the same time with coil cleaner. Just take the top plastic cover off the top of the radiator and soak the coil with coil cleaner. U can find that at Home D but its available on the link also. You ac will run much better.
    ChrisFaehrtPrius likes this.
  6. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    BG also makes a product called Frigi-Fresh. Try Amazon or Ebay.
  7. dpframing
    74
    Chester NY 10918
    2022 Prius Prime
    I might take off the right front tire to make it easier to find the hose. Also , I found a 10- lot of this for sale (10- 2 can kits with hose)- the genuine Toyota stuff. I bought the lot and maybe I'll sell them on the site if anybody wants genuine Toyota cleaner.
    ="edthefox5, post: 2250355, member: 27955"]Yes they stopped selling it otc here too.
    here:
    Also I clean the car's front evap coil also at the same time with coil cleaner. Just take the top plastic cover off the top of the radiator and soak the coil with coil cleaner. U can find that at Home D but its available on the link also. You ac will run much better.[/QUOTE]
