How to get camber on the Prius C ?
Discussion in 'Prius c Accessories and Modifications' started by emune, Feb 8, 2019.
  1. emune
    emune Junior Member
    26
    2016 Prius c
    Hey guys going really wide with my fitment
    15x9 wheels with -15 offset
    lowered on tanabe nf210 springs
    195/50r15 tires
    pulled and rolled fenders, will keep pulling once a week
    Really need to get some camber on the front and the rear to clear some of the poke I have going on.
    does anyone know what parts I need and where I can buy them to get camber?
    if anyone has any for sale please let me know
    thanks in advance
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Front is a mcpherson strut, so the normal "crash bolt" method will get you some. I don't really recommend them, but the option is there. When I built the rear coil overs for my 84 Camry I used factory eccentric bolts from a Subaru and made the strut housing compatible with them.
    more info
    For the rear you can get a little bit extra by picking up adjustment shims from an auto parts store. They are plastic disks that bolt between the wheel bearing and hub designed to fix a bent rear axle during an alignment. Again you won't get a lot out of them. There is a guy that makes sets of angled spares out of aluminum for the Scion xB, which shares the wheel bearing with the Yaris and Prius C. I have a set of 2.5 degree spaces from him that I'm not going to use if you want them let me know and I'll figure out what I paid for them and come up with a fare price from there. The final trick is the "washer trick" and you'll find details on the Yaris boards for this. Again I don't recommend this method even though it's exactly what I did to get the setting I needed on the rear of my car. I don't think you'll get where you need to be doing that though.
  3. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    There was a guy in japan that did a custom fiber glass widebody on the c. It’s sick but he is running about the same wheel set up. Just to clear it. I doubt you will wanna go to that far to run wide wheels but it’s something different
