How to get into maintenance mode on a 2013 to check the 12V Battery ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Markee, May 22, 2015.
  1. Markee
    Markee Member
    334
    South Florida Broward County
    Can someone tell me how I can get into maintenance mode on a 2013 level 4 please ?
  2. JC91006
    16,748
    8,553
    Press infophone and turn headlights on and off 3 times
    Markee likes this.
  3. Den49
    Den49 Member
    498
    272
    Maryland
  4. Markee
    Markee Member
    334
    Thanks for the reply
    I follows the instructions on that above link seems to get me into maintenance mode but ?
    I thought its supposed to display some kind of diagnostic-screen on my Nav display that lets you make some hidden adjustments and check stats and battery stats ?
    All I get is the message saying I'm in maintenance mode on the above top display nothing on the nav screen ?
  5. Den49
    Den49 Member
    498
    272
    Maryland
    That is the way maintenance mode has worked when I used it, nothing on the nav screen. I think the G2 Prius may have provided more information and functionality via the nav screen than the G3.
  6. bisco
    51,678
    easy enough to check your 12 volt under the hood with a dvm.
  7. CR94
    CR94 Senior Member
    2,681
    1,161
    Northwestern S.C.
    Or about equally easy to check at the battery. ("dvm"= digital voltmeter or multimeter)
    "Maintenance mode," as I understand, essentially means the engine runs continuously instead of automatically stopping when appropriate, so one can check or do anything under the hood that requires the engine to be on.
  8. Markee
    Markee Member
    334
    Thanks for the help
  9. JC91006
    16,748
    8,553
    you should really try what I suggested on post #2, that's the information you are looking for in the navigation screen
  10. Markee
    Markee Member
    334
    Ok let me go try that right now
  11. Markee
    Markee Member
    334
    Yeah that defiantly does work first you have to turn the Power Switch On by pressing the power button twice without your foot on the brake
    then on with my model I pressed and held in the info/apps button while turning the headlights on and off 3 times it brings you into the Maintenance mode that displays on the nav touch screen which allowing you to move around
    Without any instruction to know what I'm doing I'm afraid to mess around in there thinking I could easily mess things up
    If anyone knows how to get around in there please chime in ?
    IMG_20150524_002630.jpg IMG_20150524_002717.jpg IMG_20150524_002733.jpg IMG_20150524_002705.jpg up
    #11 Markee, May 24, 2015
