How to get OK MPG in the Fusion/Cmax hybrids
Discussion in 'Ford/Lincoln Hybrids and EVs' started by acdii, Feb 13, 2013.
  1. acdii
    acdii Active Member
    1,124
    131
    Well I was taught today what it takes to get 40+MPG in the new Fusion Hybrids. Basically forget what you know about previous hybrids, this one does not work the same. On all the Hybrids I had, I could meet or exceed EPA, and do it with ease. As long as I didnt hammer the throttle, did the usual spacing, coasting, smooth acceleration, timing lights etc, I easily got at least EPA in all 3, Prius, Camry, Fusion. But not in the 13, and doesnt look like I am the only one.
    Well the way it is done is to accelerate very slowly, say like up to 3 minutes 0-60. Once there, back out until you are on EV, and use as little battery as possible, and basically glide down until 1/4 battery, which is about 45 MPH, then speed ever so slowly back up to 60, to recharge the battery, and do it all over again. Not only will it take you twice as long to get to where you are going, but you will wind up pissing off a LOT of other drivers. But you will get up to 47 MPG if you do this JUST RIGHT!
    IOW you have to do extreme P&G just to achieve their EPA rating. Isn't this what is done to get 90 MPG in a Prius?
    I guess you all know where my next car is coming from. Clue, it wont be a Ford.
    51,746
    ouch. who taught you that?
  3. acdii
    acdii Active Member
    1,124
    131
    Service manager who road tested my car for 3 hours with a Ford Engineer to prove the car is meeting Ford standards.
    51,746
    wow, nice of them to spend so much time on it. unfortunate result to say the least.
  5. acdii
    acdii Active Member
    1,124
    131
    yep. I verified the results, but got a few people pissed at me in the process. Looks like this car is going away, I can't deal with this anymore, and looking at Camry once again, and Mazda 6, it has decent MPG 26-38, which is what the Focus I borrowed gets, which I got 39 in last night and 37 today going to work and back. Pretty fricking sad that just normal driving in the Focus nets better MPG than the Fusion, unless I P&G BIG time!
    I can try to sell this car, but I have to have a car to drive, and the more miles I put on it, the less its worth, and each day I drive it racks up 70 miles.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I can't tell if you're being serious or not but you can just slow down to get better fuel economy. I drive in the slow lane where semi's seldom allow me to go past 55 mph. I get 60 mpg on my Prius without EV and 45 mpg on my Civic rated at 36 mpg. I don't P&G. It's difficult in traffic. It only costs you an extra 5-10 minutes to get home.
  7. acdii
    acdii Active Member
    1,124
    131
    Rural roads at 55 MPH, single lane, very few places to pass. I dont speed, unless its downhill to get up the next hill.
  8. rkk
    rkk Junior Member
    33
    So they are still blaming the drivers. Like you said, driving like that in Prius you would be way above 47. It doesn't sound like you did any 65 mph freeway driving either. It's that kind of attitude that makes me want to dump my C-MAX. If I can do it without taking a bath I just might.
  9. acdii
    acdii Active Member
    1,124
    131
    Yeah, Im working on it myself, I really don't want to lose $4000 dumping it for something else, especially by going down in options, ride, handling and comfort.
    I test drove both a 2012 Camry XLE Hybrid, and an Avalon Hybrid last night. Took each one on the exact same trip, 30 minutes each, a mix of city and highway up to 55 MPH. The Camry got 41.7, the Avalon 40. Both met their EPA ratings on the test drive, and this is in temps under 30*. Neither the Cmax, nor the Fusion came anywhere NEAR their EPA ratings in the cold weather test drives.
    The Camry was used, and had 14K miles on it, so it was fully broken in, and it showed, was really easy to get it into the 40's. The Avalon had 335 miles on it, and it took a bit to coax it to 40, but I didn't have to do anything special to get there, it just took longer to warm up and relax. I can easily see it getting over 40 MPG.
    With the dealer selling at $500 under invoice on the Camry, it is very tempting to trade out, but that $4000 loss has held me back.
  10. rkk
    rkk Junior Member
    33
    That would be way too much of a hit for me. I am not happy but I am not that unhappy. $4,000 buys a lot of gas.
    acdii likes this.
  11. acdii
    acdii Active Member
    1,124
    131
    Yep, which is why I still have it. Since 2007 I have lost a total of $1000 in all the cars I have traded. Broke even or got more than I owed on all but one, and that was on a Fusion Sport.
    There is a dealer close to our work that has one on the lot, It was built in December, mine and a few others who are having the same issue, was built last week of October. Going to road test it and see if it is the same as mine, or easier to get 40 MPG in. If it is easier, then I will be calling Ford again and bashing them in on this.
  12. acdii
    acdii Active Member
    1,124
    131
    Thank you, you helped me make my decision. $4000 DOES buy a lot of gas, and window tints, and Husky mats, and spoiler, and upgraded stereo, and tires and tints for my other car. Yep. Thank you!
    I went to a different dealer as mentioned previously and drove the one they had. It did drive a little easier than mine, but I did not get to drive it at 55 for any length of time, and while watching the Instant, it was working exactly the same as mine, so just going to live with it, besides, the closest alternative to the Fusion is the Avalon, and I just cant afford one at this time, even if I didn't have a $4000 rollover.
  13. rkk
    rkk Junior Member
    33
    You are welcome, I think. Can't quite tell if that is sarcasm or not but I don't think it is. Anyway I just might check out a Volt but I doubt they could make the numbers work and the payment on the C-MAX is high enough now. Plus my wife really likes it and compared to the Santa Fe she used to drive the C-MAX would be better. I just talked her into a Leaf however so we have that for 2 years. I drive too much for the Leaf to work for me but it's just about perfect for her. It just doesn't go quite far enough for some of her shopping trips. Like I said, perfect. The other thing holding me back is the lawsuit against Ford and the EPA review. I have a feeling there might be some cash coming our way.
    If Ford would just fess up and say that yes, they overstated things and they are sorry I wouldn't be as angry. It's there attitude that nothing is wrong and if driven right 47 mpg isn't a problem. Having to hypermile the piss out of it and staying at 60 mph or below to maybe get near 47 when you could drive just about any other car that way and blow away the EPA numbers is not right. Ford saying that they get much better mileage than the Prius V when they don't isn't right. Ford lying(they drove these cars, they knew what would happen) isn't right. If they don't do something to make things better, I have purchased my last Ford.
  14. acdii
    acdii Active Member
    1,124
    131
    No sarcasm, I promise. :) I pondered, and pondered, and it still irked me even though I accepted it, and found I just can't live with it, so went to Toyota today, and was within a hairs breath of trading to the Camry, but the lack of a few of the items that are on the Fusion kept me from doing so. I thought about it some more and finally decided that what I want, I cant get, what I need, is more important. We needed a vehicle we can all fit in for long trips, gets OK gas mileage, and can tow a trailer. I was thinking of an MKT or Flex, but it would have to be a used one, and all I can find are 3 years old with lots of miles. They also get 18.5 MPG.
    I found out the Fusion 2.0 can tow 2000 pounds, fits all of us, and gets better MPG than the Flex/MKT.
    So I went back to my dealer and talked with the owner and struck a deal, when I mentioned that Toyota could get me into a new Camry for just a little more than I pay now, he didn't like that, and rather than lose me as a customer, found out what I wanted, and after searching for one, and couldnt find one, decided to order one for me, and trade out my existing one for the new one, and meet what Toyota was going to cost me. In this case though, getting exactly what I want, except a non hybrid version. The best part is that my losses are half of what I was fearing they would be. When I factor in what I paid already, and what I will be paying, which is $5 a month more, I am OK now.
    I mentioned too bad they arent building the Hybrid Titanium, he just looked at me and laughed. He said no, you dont want one of those, even with the good radio you want, you will still obsess over the MPG and will be right back where you started. He was right too. If I know the car can only get 28 Combined and I get 26, I wont care, if it is supposed to get 47, and can barely touch 35, yeah, I would be obsessed even if it was the Titanium model with the good stereo and such.
  15. Odinn
    Odinn Junior Member
    17
    SE Michigan
    fwiw acdii, The wife and I have a 2013 fusion with the 2.5L and we are getting 29-32 mpg in the cold Michigan weather. My wife loves it and of course has the heater blasting when she makes her daily commute. I am sure you'll get a lot better mpgs with the 2.0 ecoboost and with better mpg driving habits.
    acdii likes this.
  16. acdii
    acdii Active Member
    1,124
    131
    Thanks, looking forward to it, going to be about 2 months with only one car, but we will get by. I did some looking around, found a couple hitches, cargo carriers, and trailer, so this car will do what we need, where the Hybrid wont. The Hybrid accepts the hitch, but if anything were to fail in the drive line, and the car has a hitch on, then it could cause warranty issues, so not worth the hassle.
    Besides our daily driver is the 2010 FFH and it does just fine.
  17. acdii
    acdii Active Member
    1,124
    131
    Well, I finally came to a decision, and kept the car. Reason being is I talked to a certain person from California regarding a certain case. Not saying anything more on this.
    However I have done some more testing. I made a set of grill covers that completely covers the front grills. It made no difference in MPG, but does allow the car to warm up much quicker and stay warmer longer, so its a plus.
    So I tried something different, what I notice it it gets 20 MPG while propelling the car and charging the battery, so decided, what does it get when the battery is charged. So I got the battery up to 75% charge, and kept it on ICE as much as I could driving above 55 MPH. The results were immediate. I saw the MPG jump up to 30, then 35, then 40. Then I got behind someone doing P&G in a Highlander non hybrid. and got stuck on EV, which dropped MPG. However by the time I got to the city traffic there was a 3 MPG increase over what I normally got, even doing P&G.
    Trip home I was able to get it up over 60 MPH and keep it on ICE, feathering it lightly. End results was I got 44 MPG on a 26 mile trip.
    So it looks like recharging the pack with the ICE while driving uses more fuel than it should. If this is the case, it sure explains a lot.
  18. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    It's not blame, it's standard practice. If an owner reports poor FE, they test the vehicle to see whether they can achieve rated mileage. As a rule if something's that wrong you won't be able to hit it at all. They can't really do much else.
    Note that the Escape was similar in terms of driving strategy. I presume that the combination of weight and engine size meant that they favors EV. I wonder if the car's route learning allows it to lean more heavily on the battery in some circumstances.
  19. acdii
    acdii Active Member
    1,124
    131
    By any means possible. They also test it and test it until they do hit those numbers. They also do not need to hit EPA, but get within reasonable range of MPG.
    On my car when cold, you will not hit 40 MPG, not until it fully warms up, which can take up to an hour of driving highway, does it start actually hitting 40 MPG. They put over 300 miles on my car just in testing it.
  20. acdii
    acdii Active Member
    1,124
    131
    Interesting discovery. If I stay out of EV as much as possible I can get 38 MPG. If I drive to maximize EV time, it gets under that. Very strange.
