How to get prius to shut engine off more often (use battery to propel)?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mystickid, May 8, 2018.
  1. mystickid
    mystickid Junior Member
    Chicago
    Hi Guys,
    I bought 2 gen two priuses wit very different coasting behaviors.
    My first one was a water damage car but with a new engine installed and I purchased it 100k miles. What I loved about this prius so much was that almost every time I stopped pressing the gas/acceleration pedal, the prius would shut off the rumbling motor engine and just silently coast to a stop (ie. no engine rumble and awesomely quiet/silent. I eventually sold that prius. :(
    My current prius is also a gen 2 (2008) prius. But I rarely get the beautiful silent coasting on this prius when i let go of the gas/acceleration pedal. I only get the silent coasting sometimes. But the my white prius would shut off the engine and silent coast from pretty far distances.
    Is there something I can do to make my current gen 2 prius silently coast all the time from far when the gas pedal is released?
  2. JC91006
    16,468
    8,383
    Are you doing it when the car is fully warmed up? Unless your HV battery State of Charge is really low, the engine should shut off when you let off the accelerator going to a stop (unless you're doing highway speeds).
  3. dolj
    dolj Senior Member
    7,475
    3,761
    Wellington, New Zealand
    If the ICE isn’t shutting down on coast after you have been driving for about 10-15 min, come to a complete stop (where convenient and safe) leaving the car in READY and wait 10 seconds. The hybrid control then stops the ICE. After this, the ICE should stop running when coasting to a stop.
    Try that and see how it goes.
    #3 dolj, May 8, 2018
  4. JC91006
    16,468
    8,383
    What is causing this?
  5. dolj
    dolj Senior Member
    7,475
    3,761
    It is not caused by anything, it is just what it does. Goes from stage 3a/3b -> stage 4.
    See the 5 stages of Prius warm up link in my sig for full details.
    I should add, if you are using heat/AC, it can also keep the ICE running until the car is fully warmed up.
  6. JC91006
    16,468
    8,383
    I mean, why would shutting down change it?
    edthefox5 likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Ops issue is probably his hybrid battery is getting tired. Mine started doing that not shutting off along with quick tank to purple before I Prolonged it. Back to normal now.
    Op should start watching his battery behavior on the mfd closely. He may be in Stage 1 of battery death.
  8. bisco
    48,931
    how many miles on the '08? ed is probably right. 12 volt could also be an issue.
  9. dolj
    dolj Senior Member
    7,475
    3,761
    Sorry if I was not clear, the car itself is not powered off, it stays in READY. You just wait for the ICE to stop after the car is at a complete halt.
    As to why waiting for the car to stop the ICE, the only explanation I have read is that the control system does some kind of calibration and until it does this calibration, it can't ran as economically as it is possible.
    If the ICE still does not shut down of its own accord, then the next guess would be as edthefox5 guessed, a tired HV battery. Especially if the SoC meter goes down to purple and back up to green very quickly.
    [EDIT] Re-worded post #3 to try and be a bit more clear.
    #9 dolj, May 8, 2018
    JC91006 likes this.
  10. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    OP should read about the warm-up stages in @dolj post.
    You have to come to a full stop to get into the last stage.
  11. bisco
    48,931
    you mean if you start a cold prius and go out on the highway on a summer day, and get off the highway, the engine won't shut off until you come to a stop?
  12. wjtracy
    11,311
    3,588
    Northern VA (NoVA)
    I believe that is correct, but I just drive the vehicle.
  13. bisco
    48,931
    huh, i've never noticed it in 14 years, but i can be oblivious.
  14. dolj
    dolj Senior Member
    7,475
    3,761
    For some reason, when a Prius is new, you don't notice it so much. Seems to be quieter and smoother shutoff. I had my Prius for a few years, before I noticed it, then thought something was wrong with it until I found out about the 5 stages.
    It's like that scratch that is there that you never notice, then when you notice it, you can't not see it.
