How to jump from the trunk?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alicewave, Mar 8, 2020.
  1. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    2007, daughter left dome light on and I didn't drive it for about 48 hrs. Jump packs aren't working in the front, My car is in a tight garage nose in (I'm an idiot). I've accessed the battery in the trunk so a neighbor can jump me, I'm just not sure which is the positive connection point. Please help?
    49,482
    + on top, - bottom of pic
    positive has all the serious looking stuff, negative goes to the body behind the panel
    make sure you don't cross polarize the connexxions
  3. JC91006
    16,482
    8,400
    The terminal to the left (reading from the battery), is the positive (facing the front of the car). The terminal closes to the rear end of the car is the negative.
  4. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    OK thanks, I could use specific instructions on the order of connecting them
  5. JC91006
    16,482
    8,400
    I always connect positive first
  6. bisco
    49,482
    positive to positive, negative at donor car, negative on prius. engine need not be running on on the donor car.
    reverse after started.
  7. bisco
    49,482
    keep in mind, if the battery is bad, it may not jump. also, after starting, ypu need a good battery each time you shut it down. so you'll need to get it charged, or replace it
  8. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    Just so I'm clear is positive A or B?
  9. bisco
    49,482
    a and b, thats all one connexxion
    your 'neg?' is the negative
    Alicewave likes this.
  10. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    I know, I think it's ok because I know the cause of the drain, and still getting a tiny bit of light in the dome light.
  11. JC91006
    16,482
    8,400
    in your diagram, A and B are the same terminal (positive). Negative is what you written (NEG)
  12. bisco
    49,482
    it will require testing so you don't get stranded. any idea how old it is?
  13. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    I'd have to do some digging but it was not replaced with the hybrid battery last year, I would guess 5 years?
  14. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    Negative is hard to access, can I just use the bolt on the floor of the car that the battery is harnessed into?
  15. JC91006
    16,482
    8,400
    no, you need to get to the negative terminal on the battery to jump start it.
  16. Alicewave
    Alicewave Member
    76
    28
    Ithaca, NY
    We did it, thanks everyone!
  17. bisco
    49,482
    congrats!(y)
  18. ChapmanF
    15,609
    How come?
  19. JC91006
    16,482
    8,400
    Since there was confusion on where the positive and negative would be, I didn't want the OP to possibly get the connections too close together. Kept the connections well apart from each other.
    If you're jumping from the front jump points, the strut tower bolt would be good for a ground.
