How to Jump start?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Aditya, Apr 2, 2015.
  1. Aditya
    Aditya Junior Member
    LA, CA
    2014 Prius Plug-in
    Today my friend asked me to jump start his car (non-prius) and I agreed.
    When I open my plug-in prius hood, I got confused about where to connect jumper cables.
    There is no visible battery and battery terminals? Out of embarrassment I have to know step-by-step procedure for these two questions.
    (1) How can PIP jump start other cars?
    (2) How can PIP be jump started?
    Thanks
    Adi
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Don't do it. To much can go wrong ($$$) using a Prius to jump another vehicle...and be very careful if you need a jump.
    Sergiospl likes this.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  4. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    I have to agree with the above=DON'T do it. Others on the site can give you the tech reasons, but it is too big a gamble with the electronics on this car, and besides the 12volt in the Prius is small and not very powerful.
  5. Mike500
    Mike500 Senior Member
    2,593
    764
    Due to the small size of the Prius 12 volt battery, it cannot be used to jump a car needing a full sized 12 volt.
    I would only jump a Prius at the battery under the left rear fender. That being; I would only do it myself with a jump box.
    I'd only use the said jump box to jump the other person's car.
    #5 Mike500, Apr 2, 2015
  6. bisco
    49,500
    DON'T DO IT!!! tell your friend some mpg's might pass to his car, and he should buy his own prius.
    Chodronish, edc415 and priuskitty like this.
  7. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    On 1): Toyota (and everybody here) advises against it. If you want to go ahead at your own risk, the 12V battery is in the trunk on the right side.
    On 2): in the front jumper box at the left side under the hood there is a red cap which houses a +12V terminal. Connect the 12V from the other car to that and connect the ground to somewhere in tour Prius where there is a ground. The manual should cover this, so RTFM.
  8. CharlesH
    2,785
    1,152
    Roseville, CA
    The 12V battery in a Prius (plug-in or standard) is very small, since it does not have crank the engine, as the battery is called upon to do in a conventional car. All it has to do is boot up the hybrid system control computer. If the gasoline engine needs to be started, that is done with power from the large hybrid battery. Apart from not being able to provide enough amperage to start a conventional car, the current drain and various voltages that can be fed back to the charging battery from the other car can destroy the expensive electronic systems in the Prius. Even putting the Prius 12v battery on a charger if you somehow manage to drain it has a particular protocol to avoid damage to the car's systems.
    The best way to think of a Prius is a self-moving computer system.
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    What he said.
    Mostly because the Prius (and any hybrid for that matter) has a small 12 V battery that should NOT be used to run the starter on a conventional engine.
    To each his own but if it HAS jump points in the engine bay, there is NO good reason not to use them.
    Much easier and probably safer too.
    Really ? I don't think so. Reference please.
    #9 Easy Rider 2, Apr 3, 2015
  10. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    The prius is not good to jump start other cars, granted, but what is wrong with hooking up and turning your ignition on for say 10 minutes to charge someone else's battery? I've done that twice before. As long as you don't reverse the cables, I don't see what would be bad about that. Leave the other car off and don't try to start it until you've disconnected yours.
  11. Mike500
    2,593
    764
    Glad that t was your car; NOT mine...
    I'm NOT into the act of living dangerously. Let the AAA or other road service do it.
    I would NOT even AAA touch the battery on m Prius. There are too many expensive horror stories.
    edc415 likes this.
  12. Easy Rider 2
    1,584
    257
    Ocala, FL
    Potentially what is wrong with that is:
    What if the crippled car has had a catastrophic battery failure, due to a short inside or outside of the battery ?
    I might just connect the two together for a few minutes......IF the spark at the last connection wasn't a huge one......but I would NEVER turn the donor car ON. NEVER, when it is a hybrid.
    And probably never with a conventional car either. If the crippled car won't fire off immediately just by being connected to a good battery, the owner needs to call a tow truck.
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This subject was already discussed in length long time ago.
    BTW I bet (not tried it though) that 6 size AA Alkaline batteries connected in series to give 12 Volts will "jump-start" the Prius with a drained (but not ruined) 12V battery, when the array is connected correctly to the terminal at the engine bay, i.e. will be enough to bring the car into "ready" mode and then disconnected. No danger either. OK, maybe size C batteries...
    #13 giora, Apr 12, 2015
    priuskitty likes this.
  14. trentofdestiny
    1,104
    225
    Harrisburg, PA
    I've heard of a cordless power tool 14.4v or 18v battery being used this way as well
  15. Easy Rider 2
    1,584
    257
    Ocala, FL
    You need at least 8 AA cells (9 would be better), connected in series with each other and then that assembly connected in parallel with the onboard battery.
    I think several owners have done something similar already.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Sorry, meant to say 8...
  17. Mendel Leisk
    38,728
    Starting on page 544 of my 2010 Owners Manual, the connections for jumpstarting the Prius:
    (There's two step 4's, but hey.)
    And a caution, against using the Prius to jumpstart another vehicle, at the under-hood jumpstart terminal, on page 547:
    It's not clear to me from the above, if it would or wouldn't be ok to jumpstart another vehicle by connection jumper cables directly at the battery under the hatch floor. I wouldn't do it, due again to the diminutive 12 volt battery in the Prius.
    Also, whenever you're hooking up, be VERY careful to not reverse polarity: it can blow fuses (at the least) and might damage expensive electronics.
    Maybe just get a jump pack, for future?
    edc415 likes this.
  18. Maarten28
    414
    224
    Netherlands
    I know a 150W powersupply does the trick. Not sure if AA batteries are powerfull enough.
  19. Easy Rider 2
    1,584
    257
    Ocala, FL
    Also know as a 10 amp manual battery charger !! :)
  20. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    1) Read a tale from here and see if you think its a good idea to jump a car from your PiP. Jump-Starting Weirdness, 100 Amp Fuse | PriusChat
    Personally I would go with something like this:
    (weighs about a pound) and cheaper than replacing the 100 AMP DC/DC fuse.
    2) I've actually jumped my previous Prius (2005) with 2 9-volt transistor batteries.
