How to keep gas engine on ???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kye04, Feb 13, 2014.
  1. kye04
    kye04 Junior Member
    38
    Europe
    Hi. I just put on my car a LPG system. But i have a problem: in order to set the modules for the lpg, they need the car with the termic engine on , on idle.
    How can i do that ?
  2. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Turn the defroster on and raise the temperature to high.
  3. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
  4. kye04
    kye04 Junior Member
    38
    Europe
    So...no solutions ?
    I need it on idle, when the defrost is on it`s not on idle....
  5. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    CR94 likes this.
  6. fuzzy1
    10,174
    Set the parking brakes, chock the wheels, then put the gear shifter into 'B'?
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Maintenance Mode is the correct procedure. The same as disabling traction control.
    The engine will start and not turn off until power is reset.
  8. Darknula
    Darknula Junior Member
    So did you manage to set it right?
    Whats your experience driving on LPG?
    Give us some info, thanks!
  9. bisco
    49,510
    o/p was last heard from almost a year ago, try pm'ing her.
  10. b100
    b100 Member
    141
    73
    Netherlands
    Keep the accelerator pressed at 1/4 in Park
  11. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    The non maintaince mode answers mode are Hilarious!!!
    CR94 likes this.
  12. Mendel Leisk
    38,738
    Wonder how the Liquefied Petroleum Gas worked out.
