How to keep track of EV mileage
Discussion in 'Gen 5 Prius Main Forum' started by deev, Mar 31, 2024.
Tags:
  1. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    For Gen 5 Prime, if you are driving Auto mode or HV mode. Is there a way to calculate the total of the EV range for a full charge from the Display information ? I don't see a place to view "total EV range" .
    In the infotainment center - the history also does not show actual "miles" travel . (just the efficiency number).
    Just wanna to know how do you track the total EV mileage.
    Thanks.
  2. N79PT
    N79PT Junior Member
    37
    16
    Sonoma County
    2024 Prius Prime
    SE
    EV range is on the right side of the MID, above or below range for HV operations.
  3. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    what are "HV operations"?
    are you referring to the estimate range?
    I am hoping to see the actual EV miles since a full charge, while driving in Auto-mode.
    Thanks.
    tovli likes this.
  4. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    347
    269
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Not available anywhere.
    EV Auto mode that jumps between EV, HV, or EV plus HV is way too complex due to the EV mode will be using charge from the wall or charge from regen of kinetic energy imparted to the vehicle from gas.
    Even the %EV presented at the end of HV mode driving is bogus due to this complication.
  5. tovli
    347
    269
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Car cannot so I use only EV mode most trips, but if I need an HV mode segment:
    - I photograph the odometer and %battery remaining at the start of the HV segment
    - I photograph the odometer and %battery remaining at the end of the HV segment
    - I calculate the “EV miles while in HV mode” as “delta %battery * average full charge EV range”
    (42 for me if segment includes driving above 50MPH, 45 for me for slower driving)
    - I enter the trip into my spreadsheet as an EV segment and a “pure HV” segment (actual miles in HV mode minus the calculated EV mode miles)
  6. sylvaing
    sylvaing Senior Member
    1,200
    507
    That's one place Hybrid Assistant shines. In its reports, you can get a graph of what mode you're in and its consumption. It also gives a nice summary of what percentage of each mode you were in.
    The only big caveat is it's an Android only app but will run on any old android devices from 2012 and up.
    deev and tovli like this.
