How to know when it's done charging?
Discussion in 'Gen 5 Prime Charging' started by HappyHybrid, Jan 12, 2025.
  1. HappyHybrid
    HappyHybrid Junior Member
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    after having a 2007 Prius until a year and a half ago, when it died a very expensive death, I just traded in my RAV4 Hybrid that I got to replace it for a 2024 Prius Prime XSE Premium yesterday, and am in the middle of charging it for the first time as I type this. It's switched off and locked in my driveway.
    Newbie question, since all I've found in the manual so far is "when it's done charging, unplug it", but so far have yet to find HOW to know when it's done charging.
    So far the only place I've seen that tells me the charging status seems to be on the Toyota app. Other than the dashboard display (since the car is off), how do you know when it's done charging?
    TIA!
  2. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    They got rid of the 3 status lamps on top of the passenger side dash board, like on the gen4? They flash status indication while charging, off when not plugged-in and charging. You can also check the status lamps on your charge cord.
    HappyHybrid likes this.
  3. KMO
    KMO Senior Member
    1,804
    585
    Finland
    2023 Prius Prime
    Yeah, there's no proper charge indication, like the G4 had. Wouldn't be surprised if they just assume everybody is going to use the app.
    I usually just go by time - you don't have to unplug it as soon as it's full, but you know roughly how long it's going to take. Unplug it a while after that.
    If it's not cold, the green LED at the charging connector will do as a charging indicator; when cold it might come on just when it's heating. Still, if the light goes off, it should mean it's charged.
    If you really need to check charge, you can unlock and open the door, and the dash will show the charge.
    Except it's not as good as the manual makes it sound - the "door open" pop up always covers up that display, so you have to faff around to get rid of that. I think it may not be possible to dismiss the door pop up without also dismissing the battery pop up - you may need to close the door again.
    You don't really need to worry about unplugging it at any particular time though.
    My intended schedule is plugging it in the evening (if it needs charging), charging starts at midnight, it will be finished by morning commute. If I happen not to be using the car the next day, no big deal - it can stay plugged in all weekend. In cold conditions, keeping it plugged in keeps the battery warm and ready to go EV.
    I'd just say don't leave it more than 3 days - that's the time limit on the heating, so there's no point, and beyond that it's just an extra load on the 12V battery, which you need to start considering as you head into a week or more of disuse.
    (People have got overexcited about the "danger" of leaving it plugged in, due to some text in the manual pointing out leaving it plugged in isn't a good idea, and due to a fault in some 2023s that would trigger a drain while plugged in. Leaving it plugged in is just another minor load shortening storage time like leaving the keyless entry enabled or leaving the DC cut fuse fitted. But an easier one to avoid.)
    #3 KMO, Jan 13, 2025
    HappyHybrid and vvillovv like this.
  4. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    I've found that the cable is BARELY long enough to plug in from my wall outlet to the car. It works, but it's kind of a pain to unplug it and put it back in the trunk. If I leave the cap on the end, is it safe to leave it outside 24/7 if it's under an overhang? I'm fine with unplugging both ends, but I have to feed it behind a small greenhouse every time I put it back in the car; if I could leave it where it is and just unplug it each time, is that okay?
  5. KMO
    KMO Senior Member
    1,804
    585
    Finland
    2023 Prius Prime
    Mine's permanently outside, with the plug cap removed and popped into a special cradle. Assuming the US one is similar, it should be water/whatever-proof enough to cope with that, particularly if under cover. I never gave it a second thought.
    Main issue is if you treat that cable as your permanent installation, how you going to get charges elsewhere? I bought a second mode 2 cable to stay in the car - a third-party one with some fancy cable management and a "fast charge" feature. (12A for 2 hours before dropping back to the required long-term 8A - knocks 1 hour off the charging time). I was thinking that would give me enough extra length that it could be the permanent installation with the box wall-mounted, but not quite. So using the original with the box loose.
    Also picked up a lighter mode 3 cable - here in Europe they are supplying 22kW EV cables - great thick heavy 3-phase 32A things. Totally pointless for a Prius. Splashed out for a significantly smaller, lighter and more flexible 4.6kW (1-phase 20A) one. And a bag.
    (I'm not getting any commission on all those links - they just had all the bits I wanted. They're a Nordic firm with limited US presence anyway - looks like they don't sell the EV bits in the US.)
  6. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Well, for me, most of the time I just drive to work, to home, and to shopping, so don't really NEED to charge anywhere else, while I'm just driving around locally. I had it complete charged yesterday morning and was able to get from home, to work, back to home, and still had about 7% charge left when I plugged it back in last night.
    That's good to know I can just leave it where it is on the back deck when I'm doing my local driving. If I DO go someplace out of the norm, it's easy enough to go ahead and pull it if needed, but definitely easier to just leave it where it is for my day to day stuff. Thanks for the answer, and the links, may look into getting a spare cable to keep in the trunk to use for the out of town stuff.
    Do you know if cables come LONGER than the standard? Mine reaches, but BARELY. Would be nice to have more wiggle room for it.
    Thnx!
  7. BiomedO1
    2,725
    1,455
    SacTown, Ca
    The short answer is NO, not a Toyota OEM charging cable.
    I'm going to assume that your charging @ 110-120VAC. The normal current draw is 12A, so some of us will use an extension cord. The OEM manual specifically states not to do that.
    That being said; I've been using a 15 foot extension cord for 4 years now. It's a 12 gauge stranded copper wire and I check it semiannually as the car is charging. I've already had to snip and replace both ends of the cord; due to heat buildup at the connections. I believe that 'not so cheap' construction grade extension cord was put together sloppily. I replaced both ends with hospital grade plug and receptacle. Been 3 years now, no more issues, but I still check it with an IR temperature gun once in a while.
    Since your outside, you need to make sure the connections don't end up in a puddle; otherwise that puddle could get energized and someone could get hurt.
    Hope this helps.....
  8. Paul Gregory
    Paul Gregory Senior Member
    1,365
    356
    Alberta
    2024 Prius Prime
    XSE
    I got tired of packing my OEM charging unit away all the time, so I bought a 3rd party charger off Amazon for $160 Canadian. I was also concerned about theft, considering that a Toyota replacement was quoted to me at $1600. I have been using this one for almost a year, and I think I like it better than the OEM.
  9. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Yeah, standard 120 outlet. I DO have a heavy duty extension cord that is out there all the time (it's made for outdoors, we use it with our leaf blower in the fall, it goes almost all the way to the back end of the yard), wasn't sure if plugging it into that would be okay, since the manual specifically says NOT to do that. As a newbie, haven't wanted to do something that might set the house or car on fire. But if it it's safe, since I have to park the car so close to the house to reach the included cable, I've discovered I can't get the garbage cans to the curb without moving the car twice and plugging it in afterwards. Would be nice to park it once, move the cans, then plug in after that.
  10. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Also, didn't I see in the manual that there's supposed to be a cap that goes over the port on the car itself? Did they do away with that on the 2024, or did the dealership just forget to make sure that was included? Seems like a handy thing to have, to keep the road grunge from getting in the port while driving.
  11. BiomedO1
    2,725
    1,455
    SacTown, Ca
    my advice is to use the shortest 12 gauge wired extension you need. the longer the cord = higher resistant. Get a harbor freight IR temperature gun to check for heat buildup at the connection ends while the car is charging. Heat is a by-product of high resistance, which means bad/loose connection. Also check the circuit your charge cable is connected to. you may pop the circuit breaker if other high current appliances are plugged into that same circuit. Install a GFCI outlet to wherever your plugging-in, just to be on the safe side. That big black brick on your charging cord is suppose to also disconnect, if there's issues - the GFCI outlet is an additional safeguard to keep your house from burning down....
    Hope this helps......
    My gen4 has a dust cap on my OEM charge cord and one on the car port. If your missing one - go to the dealership and check out their cars on the lot.
  12. Paul Gregory
    1,365
    356
    Alberta
    2024 Prius Prime
    XSE
    I couldn't post the Amazon link earlier, so let's see if this will work:
    https://shorturl.at/xwv2P
    Although it's advertized as Level 2, it's not. You can connect it to 240V, and it will deliver 16 amps, I believe, but that isn't Level 2 charging.
  13. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Excellent, thank you. It's showing $202, but that's likely Canadian, thinking I should be able to find the same thing on the US site (ooh, just checked, lots of choice, varying prices). Would be nice to have two, one for the trunk to charge when I'm out and about, and one left set up on the back deck.
  14. HappyHybrid
    34
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    New question... how long does it take before the "OMG, I'm using GAS!" thought goes away when you actually have to use gas? If I go straight to work and then back home, I'm fine, I can get home and still have charge left. But went to see Nosferatu after work last week, so put a few extra miles on it getting to the theater then home, plus when I got out, it was 20something degrees out, so by the time I got home, I'd run out of charge and had dropped from 506ish miles remaining on the tank down to around 500, and I was horrified, lol. And then didn't even get a full charge in overnight, since I didn't get home until 10:30. So now I'm down to 490something.
    I'm thinking it's like when you get a new pair of white sneakers and get the first scuff on them, assuming I'll get used to having to actually use gas at some point, but now if it runs out of charge, I'm just :eek: . :D
    PrimeDan likes this.
