How to let Prime to remember HV mode
Discussion in 'Prime Main Forum (2017-2022)' started by Roy2001, May 25, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    My friend bought a Prime but he can’t charge it as he lives in apartment.
    The best way to ensure battery life and vehicle performance should be with 40-50% charged traction battery. But every time when I start the vehicle it would squeeze the last bit of electricity in EV mode automatically before switching to HV mode.
    Is there any way to let Prime remember the last used mode?
    MikailSJ likes this.
  2. FyeUK
    FyeUK Junior Member
    25
    16
    UK
    Not in my UK version as far as I’m aware...
    Why is it getting a plug in vehicle if he can’t plug it in? If it’s only a temporary thing while he’s moving house or whatever then I wouldn’t worry about the state of the battery too much - it shouldn’t be impacted much.
  3. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I don't think there's a way to change that. He'll have to use the Charge Mode to keep it around 40% to 50% if he can't plug in.
  4. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    I do not see anything wrong in using the Prime as a normal HV vehicle, with the bonus of a big traction battery that can be charged not only through the grid but even through CHARGE mode, or descending hills. However, pressing the HV pushbutton to stay all the time in HV mode it's not a big deal... maybe a "PRESS HV" post-it on the dashboard could help at this regard.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    THIS.
  6. bisco
    51,155
    toyota states that the best resting place for the battery is wall charge completely discharged, and anywhere in hv mode charge.
    perhaps the prime battery is somehow different from a laptop or cellphone.
  7. Trollbait
    12,351
    Some in California are buying the Prime for the single occupant HOV access. This was also the case with the PiP and Volt. The other incentives making it cheaper than a Prius doesn't hurt.
  8. Roy2001
    371
    158
    Sacramento, CA
    Thank you all. Looks like he has to change mode to HV every time.
