How to make my Prius quieter
Discussion in 'Gen 2 Prius Main Forum' started by sea-horsea, Sep 10, 2007.
  1. sea-horsea
    sea-horsea Junior Member
    97
    I've read some posts way before i got my prius about mod. the doors and it will reduce the noise while driving high speed...I try to remmebered the product called but no luck. Has anyone done the mod. to their prius and does it really improve a lot? if so can you share your tricks/installation/where to purchase and all the info. you have? thank you
  2. skandale
    skandale Member
    101
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Tires and tire pressure also make a big difference.
    Tom
  4. Ken S
    Ken S Member
    191
    Pittsfield, MA
    <div class='quotetop'>QUOTE(qbee42 @ Sep 10 2007, 09:52 AM) [snapback]510010[/snapback]</div>
    All in all you can't make that big of a difference though. I put it in my doors and floor and while it is better than before...you'll never get close to the quiet of some of the luxury cars out there. I've also changed tires and, once again, while better...there's still significant road noise.
  5. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Try parking it in a library, and let the librarians shush it until it learns to be quieter.
  6. hill
    8,640
    <div class='quotetop'>QUOTE(sea-horsea @ Sep 10 2007, 05:09 AM) [snapback]509946[/snapback]</div>
    It'd be nice to know what your view is on 'high speed' ... 50? 60? breakin' the law?
    Our Prius is extreamly quiet, while hyper mileing ... or when we take bikes in stead. More data please.
  7. hoop
    hoop On The South Texas Coast
    69
    middle of south Texas coast
    <div class='quotetop'>QUOTE(hill @ Sep 10 2007, 11:31 AM) [snapback]510089[/snapback]</div>
    My touring is very quiet. It mostly depends on what the surface of the road is. Other than tire noise there isnt much at all.
  8. qbee42
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(hoop @ Sep 10 2007, 12:41 PM) [snapback]510095[/snapback]</div>
    Same with the standard version. Almost all of the noise is road noise from the tires and road surface. The only exception to this is when the ICE revs up to warp drive.
    Tom
  9. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I've used about 80sf of Secondskin's Damplifier on mine. Doors, floor, roof, trunk, and hood.
    The avg noise level inside my car at 65mph on Hwy 75 has gone from about 82db to 72db.
    On some quieter roads I've registered as low as 68db at the same speed.
    I'm thinking of adding Spectrum to the wheel wells to reduce tire noise. It's the biggest annoyance
    now that everything else has quieted down quite a bit... :)
    I think 2nd Skin is a much better value than Dynamat, which is way overpriced.
    You can view their products here: http://secondskinaudio.com/
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I have B-Quiet Extreme installed.
  11. qbee42
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Sep 11 2007, 01:13 PM) [snapback]510656[/snapback]</div>
    Maybe you could do it like a Russian sub and cover your Prius with six inches of rubber.
    Tom
  12. acdii
    acdii Active Member
    1,124
    131
    Compared to the Crown Vic and Grand Marquis, the Prius is very quiet, Depending on the road, when it is smooth the car is very quiet. What surprised me the other day on the highway, I had my window down and a semi came up along my drivers side, and was loud. I rolled the window up and was the noise went way down to where I barely heard it. When you consider the type of car, the size of it and such, the prius is a very well made quiet comfortable car, unlike earlier models of Toyotas, where road noise and engine noise were all you heard.
