How to make the HV battery fan to run all the time?
Discussion in 'Prime Main Forum (2017-2022)' started by ESh, May 23, 2023.
  1. ESh
    ESh New Member
    MI
    2020 Prius
    Luxury
    Is there any possible way to make the fan run all the time, automatically, without using Dr. Prius or similar app?
    The idea is to net let the battery run hot.
    Thanks.
    Plugin_RK likes this.
  2. Plugin_RK
    Plugin_RK Member
    94
    28
    Pacific Coastal city
    2018 Prius PHV
    This is an interesting idea. Toyota's goal is probably to reduce energy consumption and only use the fan when it is most effective.
    I used to have a Hewlett Packard business laptop with a fan that was off most of the time. The fan didn't run mostly and allowed the temperature to build up until it was hot esp. for the CPU, then the fan turned on - unfortunately the fan was unpleasantly loud. So, HP made a firmware modification allowing the user to choose to run the fan at low speed permanently as an option, which many users enabled. This was great as it reduced fan noise dramatically, indicating presumably that the laptop was seldom operating at higher temperatures (... but at the expense of increased energy use).
    So, your suggestion might similarly result in lower average HV battery temperature. Presumably, this would incur slightly higher energy usage but this may be of no concern e.g. if your daily commute doesn't deplete the battery. For example, my daily commute to work leaves between about 10% and 20% battery level depending on season, etc.
    #2 Plugin_RK, May 27, 2023
    49,492
    i know you can run the fan with a scan gauge, but idk if you can run it manually
  4. Plugin_RK
    Plugin_RK Member
    94
    28
    2018 Prius PHV
    Could it be as simple as connecting the fan via a manual switch to a suitable power source in the car i.e. bypass the automatic control?
  5. bisco
    49,492
    idk, the fan speed is controlled by the attached logic board, so you would have to now something about the electronics.
  6. Plugin_RK
    Plugin_RK Member
    94
    28
    2018 Prius PHV
    It would depend on the type of fan. Many older fans just required power to their terminals and they'd run, which would bypass any electronics completely.
    That's not always the case though. There might also be a sensor detecting whether the fan runs or not to protect against loss of cooling leading to battery overheating. Someone will know, unfortunately I don't.
  7. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    A possible work around would be to mount a small fan over the air inlet and have it run whenever the car was on. The existing fan could still come on if needed.
  8. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Part of making a fan that only runs as much as needed is so that the item to be cooled gets exactly enough cooling.
    Another part of it is making sure the fan lasts as long as the rest of the car.
    If you do rig your fan to run full-time, make a reminder to check on it periodically, because it might not last as long as it was originally designed to.
    Trollbait and Mendel Leisk like this.
  9. Mendel Leisk
    38,726
    A little cooling is good, so more is better? Maybe yes; maybe no?
    The fan is also multi-speed, about five speeds IIRC: so full speed all the time?
    I’d think Toyota’s engineers thought a lot about this, dialled in fan activation and speed carefully.
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    Sometimes the battery needs to be warmed up so forcing full speed fan will slow that process. Remember the battery is not a human who performs better at 72f.
  11. bisco
    49,492
    can a battery receive too much cooling, outside of cold weather?
  12. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    It can receive too much dust. More air means more dust.
  13. bisco
    49,492
    interesting, i never thought of that
  14. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
  15. rjparker
    7,976
    4,717
    Texas Hill Country
    EV range is different than an air cooled hybrid battery's best operating temp. EVs use battery power to heat the cabin and to heat or cool the battery. Running a hybrid battery's fan faster than necessary (which varies) just reduces efficiency and increases fan wear and blower accumulations. If a hv battery is overheating its usually a clogged blower or a really bad battery.
  16. prius16
    462
    243
    New England
    2022 Prius Prime
    Sorry, there isn't anything magic or special about the hybrid or EV batteries that Toyota uses.
    Yes, every vehicle manufacture has there own very specific requirements.
    However, the general uses/limitations exist.
    Battery temperature is battery temperature.
    I'm not going to argue, or debate, something extremely basic, and super well known.
    Google.....
  17. Mendel Leisk
    38,726
    I had a Scangauge monitoring the middle temp sensor on hybrid battery (on our ‘10). I recall one cool evening, driving a quiet coastal highway, on a cool evening, around 80 kms (50 miles) an hour. The sensor temp stabilized around 35C, while ambient was maybe 18C. That seemed a baseline case, what the engineers were aiming for?
  18. bisco
    49,492
