How to manually pop the trunk with a dead battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Jul 29, 2016.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    Anyone know?
    ETP likes this.
  2. JC91006
    16,674
    8,519
    There is a latch in the center where the trunk meets the body
    ETP likes this.
  3. nicoj36
    518
    162
    Can you post a pic pretty please? (y)
    ETP likes this.
  4. 3PriusMike
    3,092
    2,413
    Silicon Valley
    I don't have a pict...but you pop off a plastic cover next to the latch.
    Best to try when you don't have a dead battery.
    Mike
    ETP likes this.
  5. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    I had to do this. The pics are in the manual. You have to remove the plastic cover, then move the latch over while someone out side lifts. Don't loose a finger.:ROFLMAO::LOL::mad:
    Needs reengineered.
    Jumper terminals under the hood.
  6. qdllc
    qdllc Senior Member
    1,371
    399
    This.
    So long as you either use foolproof jumper cables (won't allow wrong polarity connections to work) or just do it right. Attaching a good battery in parallel to a dead one will provide ample power to do most "static" things with the electrical system.
  7. bisco
    51,155
    the easier way is to hook a battery/jump start to the 12v under the hood. then you can open it normally, without the climbing in back and fumbling around.
    ETP likes this.
  8. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I've tried the climbing-in-back method few times. It's not difficult to do unassisted. Finding by feel the proper lever to pull somehow takes me longer than it should, although it isn't hard to reach.
  9. mrbigh
    3,686
    699
    Long Island, NY
    It is very cumber-son to unhook the rear latch when you have "stuff" in the cargo area
  10. bisco
    51,155
    like a body?
    GREEN BAE likes this.
  11. mrbigh
    3,686
    699
    Long Island, NY
    depends on witch town you are in..............:censored:
  12. ETP
    2,802
    1,170
    Auburdale FL
    Exactly. I forgot about the terminals under the hood when it happened to me. Just jump it and drive it to the dealer and get a new battery.
    Life is too short. BTW buy a new one (2016). The battery is under the hood.
  13. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I still prefer an "alarm battery". Available at alarm places and others - a gell cell battery of 5-10 A-Hr and quite inexpensive - about $20. Works just fine at the "jump point". Just take care to get the polarity correct. Positive on the jump point, negative on the chassis. The same place you get the battery can sell you an inexpensive charger for it. Or get a "Battery Tender" and use it on the car too when you park it for extended periods.
  14. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  15. ETP
    2,802
    1,170
    Auburdale FL
  16. priusrust
    priusrust Member
    197
    68
    MA
    ok- this video is good. I have a gen2 2004 prius. why am I here?- cause this came up in google search. My battery died and could not open hatch. 1) climb in through side door 2) remove folding spare tire floor cover to expose plastic storage basin above tire 3) look towards hatch 4) you see a rectangular cut out that lines up with cut out in video above 4) reach in....fiddle around until you feel lever- pull up- hatch open
  17. bisco
    51,155
    thank you and well done!(y)
  18. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    I purchased a spare EC5 cable for my jump pack, removed the clips and replaced them with lugs, so that I could attach them directly to the battery post terminals.
    When my battery died a couple of month's ago, I just went over the back seat and connected the jump pack and started the car. Then the door switch released the hatch lock. pigtail on Prius v.JPG
  19. Mendel Leisk
    40,586
    Or just use the under-hood jump point?
    fuzzy1 and bisco like this.
  20. fuzzy1
    10,335
    Pigtail attached at either location, the dedicated connector makes for easier, more convenient use of a battery tender.
    Georgina Rudkus likes this.
