How to override the Prius (gen3) Battery Cooling Fan.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Panicos, Aug 14, 2021.
  1. Panicos
    Panicos Junior Member
    38
    16
    Cyprus
    Hi. I am searching for a relatively "easy way" to turn my battery cooling fan ON, whilst charging / disscharging the HV battery.
    I made a plain grid charger (by copying others off course) and a discharger, but most people say i must turn the cooling fan ON to avoid overheating the batteries.
    Somewhere in the forums i've read that you connect "so an so" and it works like a charm. I could not understand it.
    Can anyone please help? With pictures it would be great.
    Thanks
    Later in September 2021 i can upload photos of my grid charger / discharger if anyone wants. I have not built it yet because im waiting for the parts.
    Meg&Bear likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,063
    4,504
    Pacific Northwest, USA
    I look forward to learning about this because Gen3 cooling fan is a three wire system and Gen2 is easy with a 2 wire system that pulls about 6.5v DC when it is running at its peak. If someone on here, maybe @Elektroingenieur could post how the wiring works on Gen3 cooling fan so we don't have to depend on Prolong for their expensive fan controller box they sell with their overpriced harness that'd be much appreciated.
    Meg&Bear and Panicos like this.
  3. ChapmanF
    15,466
    Covered here.
    At the time I wrote that, I hadn't found information on the SI0 waveform in the manual, but it's in there, I just missed it. Waveform 5 at the front of the Power Management Control ECU diagnosis section. Looks like about a 400 Hz square wave (by eyeball), and I'm guessing the % of duty it is pulled down gives the requested speed (given that grounding it seems to work on the bench to make the fan run).
  4. Panicos
    38
    16
    Cyprus
    There are four wires coming out of the cooling fan. plug S14.
    Indeed the Prolong fan harness is a bit of expensive.
  5. Panicos
    38
    16
    Cyprus
    Thanks for chipping in... This is what i've read but not have a clue...
  6. Panicos
    38
    16
    Cyprus
    Do you mean, whilst the battery pack is connected in the car, I should connect S10 with GND0? Whilst S14 plug is connected to the fan?
  7. ChapmanF
    15,466
    As a general note, sometimes great care is needed to keep details from blending together.
    The connectors in the car's electrical system are given names with a letter and number. When Elektroingenieur mentioned connector S14 at the blower motor, that was the name of that connector.
    The individual circuits running through a connector also have names, in addition to their pin numbers. Their names are memory jogs to suggest their purpose; IG0 and GND0 are good examples. Sometimes the names aren't very obvious: SI0 (and notice those are the letters S and I, and digit 0) might stand for something like Speed Input, and VM0 might be something like Voltage Monitor ... it's the signal returning from the fan that shows how fast it is turning.
    In particular, in this example, the "S14" (name of a connector) and "SI0" (mnemonic name of a circuit) look sort of similar, but are totally different kinds of things.
    In normal operation, the ECU tells the fan how fast to run by sending pulses to it on SI0. A train of pulses will alternate between ground and some higher voltage, and I think this signal is arranged so that the more time the pulse train spends at ground, the faster the fan runs. That would explain the suggestion to simply ground SI0 for testing on the bench, and that would make the fan run full speed. (I'm still drawing inferences that aren't completely spelled out, though.)
    Elektroingenieur was suggesting a method to test the fan on the bench, where you would just put +12 from a battery across IG0 and GND0, and then ground SI0 to make the fan start.
    I think I would be more careful about just blindly grounding SI0 while the fan is installed in the car though. You'd not just be supplying an input to the fan then, you'd also be pulling down the ECU's speed signal output. Maybe that's ok, but it merits some thought.
    It kind of sounds like the pullup in that circuit is on the fan end, which would make it probably ok. But I shouldn't set your comfort level modding your car.
    #7 ChapmanF, Aug 16, 2021
  8. Panicos
    38
    16
    Cyprus
    Thank you sir. Yes its risky to try and do something without being 100% certain.
  9. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
  10. CT200Star
    CT200Star Junior Member
    Marietta, GA
    Did you mean put +12 from a battery across IG0, and then ground SI0 and GND0?
  11. ChapmanF
    15,466
    You could write it that way if you wanted (but then change 'across' to just 'on').
    Generally, when you see "put twelve volts across two terminals", that already is telling you to connect those two terminals so they are twelve volts apart, such as +12 to one and ground to the other.
    I chose to say it that way just to make it clearer that IG0 and GND0 are how the fan gets its power to operate, and SI0 tells it when and how fast.
